Hi All,
While I am trying to build the geoserver I am getting below the error
“Could not instatiate converter : com.thoughtworks.xstream.converters.enums.EnumMapConverter : null”
I am building using the maven, using command: mvn -DskipTests clean install
Googling around didn’t help either. So this mail
For more details please see below the stack trace.
FATAL ERROR
Could not access java.util.EnumMap.keyType field
Trace
com.thoughtworks.xstream.XStream$InitializationException: Could not instatiate converter : com.thoughtworks.xstream.converters.enums.EnumMapConverter : null
at com.thoughtworks.xstream.XStream.dynamicallyRegisterConverter(XStream.java:668)
at com.thoughtworks.xstream.XStream.setupConverters(XStream.java:640)
at com.thoughtworks.xstream.XStream.(XStream.java:375)
at com.thoughtworks.xstream.XStream.(XStream.java:301)
at org.apache.maven.plugin.war.util.WebappStructureSerializer.(WebappStructureSerializer.java:25)
at org.apache.maven.plugin.war.AbstractWarMojo.(AbstractWarMojo.java:237)
at org.apache.maven.plugin.war.WarMojo.(WarMojo.java:44)
at java.lang.Class.newInstance(libgcj.so.90)
at org.codehaus.plexus.component.factory.java.JavaComponentFactory.newInstance(JavaComponentFactory.java:44)
at org.codehaus.plexus.DefaultPlexusContainer.createComponentInstance(DefaultPlexusContainer.java:1464)
at org.codehaus.plexus.component.manager.AbstractComponentManager.createComponentInstance(AbstractComponentManager.java:93)
at org.codehaus.plexus.component.manager.PerLookupComponentManager.getComponent(PerLookupComponentManager.java:48)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:331)
at org.codehaus.plexus.DefaultPlexusContainer.lookup(DefaultPlexusContainer.java:440)
at org.apache.maven.plugin.DefaultPluginManager.getConfiguredMojo(DefaultPluginManager.java:609)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:429)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:558)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:499)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:478)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:330)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:291)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:142)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:336)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at java.lang.reflect.Method.invoke(libgcj.so.90)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: java.lang.reflect.InvocationTargetException
at java.lang.reflect.Constructor.newInstance(libgcj.so.90)
at com.thoughtworks.xstream.XStream.dynamicallyRegisterConverter(XStream.java:661)
…29 more
Caused by: java.lang.RuntimeException: Could not access java.util.EnumMap.keyType field
at com.thoughtworks.xstream.core.util.Fields.find(Fields.java:18)
at com.thoughtworks.xstream.converters.enums.EnumMapConverter.(EnumMapConverter.java:29)
…30 more
Total time: 7 minutes 14 seconds
Finished at: Fri Nov 27 04:14:24 GMT 2009
Final Memory: 126M/195M
Yash
Please help Logica to respect the environment by not printing this email / Pour contribuer comme Logica au respect de l’environnement, merci de ne pas imprimer ce mail / Bitte drucken Sie diese Nachricht nicht aus und helfen Sie so Logica dabei, die Umwelt zu sch?tzen. / Por favor ajude a Logica a respeitar o ambiente n?o imprimindo este correio electr?nico. This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.
