I can add shape in geoserver with no problems. and i can display it in
mapbuilder.
than i also have a raster. it's a tif in gauss kreuger (same as shape).
there's a tfw and same prj as above. and then i create a new CoverageStore.
This works. But then i try creating a coverage from this store i get this
exception:
The following exception was thrown:
org.vfny.geoserver.global.ConfigurationException: Converting Envelope to
Lat-Lon WGS84: org.opengis.referencing.operation.OperationNotFoundException:
Bursa wolf parameters required.
mapbuilder.
than i also have a raster. it’s a tif in gauss kreuger (same as shape).
there’s a tfw and same prj as above. and then i create a new CoverageStore.
exception:
Can anyone explain why shape is working and raster is not?
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
mapbuilder.
CoverageStore.
exception:
Lat-Lon WGS84:
easier
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
easier
mapbuilder.
CoverageStore.
exception:
Lat-Lon WGS84:
org.opengis.referencing.operation.OperationNotFoundException :
easier
easier
I did a small test and it's working as it should! great job removing the
bug!!
Alessio Fabiani wrote:
Yes, I have committed the changes ... can you try please?
On 8/22/06, GeoUser <blazrepnik@anonymised.com> wrote:
found the problem?
> Mmmm, it seams like we are not considering the Lenient datum hint ...
let
> me
> see where !!!
> I'll give you a feedback ASAP.
>> Hey!
>> I have a shape file (roads) in gauss kreuger. i also have the tfw and
prj
>> file. the prj file looks like this:
PROJCS["D48_3_degree_GK_Zone_3",GEOGCS["GCS_Hermannskogel",DATUM["D_Hermannskogel",SPHEROID["Bessel_1841",
>> 6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",
>> 0.0174532925199433
]],PROJECTION["Gauss_Kruger"],PARAMETER["False_Easting",
>> 5500000.0],PARAMETER["False_Northing",5000000.0
>> ],PARAMETER["Central_Meridian",15.00],PARAMETER["Scale_Factor",0.9999
>> ],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
>> mapbuilder.
shape).
>> CoverageStore.
this
>> exception:
to
>> Lat-Lon WGS84:
>> View this message in context:
>> http://www.nabble.com/gauss-kreuger-shape-and-raster-tf2145046.html#a5921776
>> Sent from the GeoServer - Dev forum at Nabble.com.
security?
>> easier
>> Geronimo
>> _______________________________________________
> Eng. Alessio Fabiani
> Vice President/CTO GeoSolutions
> http://www.geo-solutions.it
security?
> easier
Geronimo
easier
easier
