[Geoserver-devel] [gdal-dev] GML lat-lon coverages and interoperability
Great, first hit from Andrea. I am awaiting if Even strikes back. His creation (GDAL JP2OpenJPEG driver) writes out EPSG:4326 coverage into GML JP2 this way, without having gridFunction.
<gml:FeatureCollection
xmlns:gml=“http://www.opengis.net/gml
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xsi:schemaLocation=“http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlJP2Profile/1.0.0/gmlJP2Profile.xsd”>
gml:boundedBy
<gml:Envelope srsName=“urn:ogc:def:crs:EPSG::4326”>
gml:lowerCorner61.7282236395245 24.7248340978191</gml:lowerCorner>
gml:upperCorner61.7838827490233 24.8422668729657</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
gml:featureMember
gml:featureMember
<gml:RectifiedGridCoverage dimension=“2” gml:id=“RGC0001”>
gml:rectifiedGridDomain
<gml:RectifiedGrid dimension=“2”>
gml:limits
gml:GridEnvelope
gml:low0 0</gml:low>
gml:high15517 7354</gml:high>
</gml:GridEnvelope>
</gml:limits>
gml:axisNamex</gml:axisName>
gml:axisNamey</gml:axisName>
gml:origin
<gml:Point gml:id=“P0001” srsName=“urn:ogc:def:crs:EPSG::4326”>
gml:pos61.7838789652633 24.7248378815791</gml:pos>
</gml:Point>
</gml:origin>
<gml:offsetVector srsName=“urn:ogc:def:crs:EPSG::4326”>0 7.56751998624388e-006</gml:offsetVector>
<gml:offsetVector srsName=“urn:ogc:def:crs:EPSG::4326”>-7.56751998624388e-006 0</gml:offsetVector>
</gml:RectifiedGrid>
</gml:rectifiedGridDomain>
gml:rangeSet
gml:File
gml:rangeParameters/
gml:fileNamegmljp2://codestream/0</gml:fileName>
gml:fileStructureRecord Interleaved</gml:fileStructure>
</gml:File>
</gml:rangeSet>
</gml:RectifiedGridCoverage>
</gml:featureMember>
</gml:FeatureCollection>
-Jukka-
Lähettäjä: andrea.aime@…403… [mailto:andrea.aime@…403…] Puolesta Andrea Aime
Lähetetty: 3. huhtikuuta 2017 15:58
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Kopio: ‘gdal-dev@…1232…’ (gdal-dev@…1232…) <gdal-dev@…1232…>; geoserver-devel@lists.sourceforge.net
Aihe: Re: [gdal-dev] GML lat-lon coverages and interoperability
On Mon, Apr 3, 2017 at 2:32 PM, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
With orthophoto coverages I believe that all cases could be handled with the default gridFunctions: startPoint at gml:Low, axisOrder +1 +2, sequence rule “Linear”. As far as I have understood GDAL trusts that this is also what the other partners do. However, it seems that GeoServer developers have decided to handle the latitude-longitude axis flip in WCS 2.0.1 by changing the order of grid axis with a function instead of writing the offsetVectors to suit with the default +1 +2 axis order.
gml:coverageFunction
gml:GridFunction
<gml:sequenceRule axisOrder=“+2 +1”>Linear</gml:sequenceRule>
gml:startPoint0 0</gml:startPoint>
</gml:GridFunction>
</gml:coverageFunction>
Hi Jukka,
the decision was not arbitrary, and imho, necessary.
Rasters pixels are normally represented as east/north, but OGC forces us to describe geographic data in lat/lon order.
So how do you tell the client, “look, I’m telling you that the axis order is north/east, but really, I’m giving you back data in east/north order instead”?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Mon, Apr 3, 2017 at 3:19 PM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
    <gml:Envelope srsName="urn:ogc:def:crs:EPSG::4326">
      <gml:lowerCorner>61.7282236395245 24.7248340978191</gml:lowerCorner>
      <gml:upperCorner>61.7838827490233 24.8422668729657</gml:upperCorner>
Can you clarify which one is longitude and which one is latitude? :slight_smile:
It's one thing that really gets me about CITE tests too, if they wanted to
make order obvious without further specs, the
coordinates of test data could have had some values greater than 90 :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
I don’t really have an opinion on this. I haven’t read the relevant part of the GML or GMLCOV spec and I’m afraid I wouldn’t understand it well. The GDAL GMLJP2 code just follows what the GMLJP2 spec and examples suggest, as well as data productions. Perhaps it is not “correct”…
His
xsi:schemaLocation="http://www.opengis.net/gml
file.xsd">
gml:boundedBy
</gml:Envelope>
</gml:boundedBy>
gml:featureMember
gml:featureMember
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
gml:origin
24.7248378815791</gml:pos> </gml:Point>
</gml:origin>
<gml:offsetVector
0</gml:offsetVector> </gml:RectifiedGrid>
gml:rangeSet
gml:File
</gml:File>
</gml:rangeSet>
-Jukka-
Lähettäjä: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Puolesta
Andrea Aime
Vastaanottaja: Rahkonen Jukka (MML) jukka.rahkonen@anonymised.com
Kopio: ‘gdal-dev@anonymised.com’ (gdal-dev@anonymised.com)
gdal-dev@anonymised.com; geoserver-devel@lists.sourceforge.net
Aihe:
<jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com
gml:GridFunction
</gml:GridFunction>
Hi Jukka,
"look, I’m telling you that the axis order is north/east, but really, I’m
giving you back data in east/north order instead"?
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
x.com
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Spatialys - Geospatial professional services
http://www.spatialys.com
Adding mapserver-dev to recipients in hope that Stephan Meissl notices and could share his opinion. Mapserver WCS 2.0.1 does not generate axisOrder.
-Jukka Rahkonen-
Lähettäjä: Even Rouault even.rouault@anonymised.com
Lähetetty: 3. huhtikuuta 2017 23:03
Vastaanottaja: gdal-dev@anonymised.com
Kopio: Rahkonen Jukka (MML); Andrea Aime; geoserver-devel@anonymised.comceforge.net
His
file.xsd">
gml:boundedBy
</gml:Envelope>
</gml:boundedBy>
gml:featureMember
gml:featureMember
gml:limits
gml:GridEnvelope
</gml:GridEnvelope>
</gml:limits>
gml:origin
</gml:origin>
<gml:offsetVector
gml:rangeSet
gml:File
</gml:File>
</gml:rangeSet>
-Jukka-
Andrea Aime
Aihe:
gml:GridFunction
</gml:GridFunction>
Hi Jukka,
Ing. Andrea Aime
@geowolf
Technical Lead
