[Geoserver-devel] GDAL lib and imageio-ext 1.1.7 for macOS compiled succesfully - how to install ?
Hello Geoserver-Developers,
Well I'm not sure if i should post that here (or on the geoserver-users mailing list), but it seems related to Geoserver development, so here we go:
We have Geoserver 2.10.1 running on macOS 10.11 but we need ENVI file support, that's why I compiled the latest gdal 2.1.3 libraries manually
to allow compilation of the java binding file for gdal-format.
The gdal native libraries are installed in /usr/local/lib/
I copied the "gdal.jar" java binding file to geoserver/WEB-INF/lib/ along with imageio-ext recommended .jars files, as described here
http://docs.geoserver.org/latest/en/user/data/raster/gdal.html
However the ENVI format in "Raster Data Sources" is not available.
It seems that Geoserver doesn't recognize the "gdal.jar" binding file, even if I rename it to "imageio-ext-gdal-bindings-1.9.2.jar"
( Geo-Solutions Java Binding file it is named "imageio-ext-gdal-bindings-1.9.2.jar" file in th
So my question is:
Does someone know how to properly setup the gdal.jar binding file so that GEOSERVER could recognize it ?
Note that I even compiled the ImageIO-Ext 1.1.7 plugin for macOS (by correcting the pom.xml files) (which I don't think it's required since the .jars can be downloaded from
http://demo.geo-solutions.it/share/github/imageio-ext/releases/1.1.X/1.1.16/
For compilation Info:
GDAL configure command (needed Kyng Chaos UnixImageIO, PROJ and GEOS frameworks)
#cd gdal-2.1.3
#./configure --with-threads --disable-static --without-grass --with-jasper=/Library/Frameworks/UnixImageIO.framework/unix \
--with-libtiff=/Library/Frameworks/UnixImageIO.framework/unix --with-jpeg=/Library/Frameworks/UnixImageIO.framework/unix \
--with-gif=/Library/Frameworks/UnixImageIO.framework/unix --with-png=/Library/Frameworks/UnixImageIO.framework/unix \
--with-geotiff=/Library/Frameworks/UnixImageIO.framework/unix --with-pcraster=internal --with-geos=/Library/Frameworks/GEOS.framework/unix/bin/geos-config --with-static-proj4=/Library/Frameworks/PROJ.framework/unix\
--with-expat --with-python -with-java -with-jvm-lib=/Library/Java/JavaVirtualMachines/jdk1.8.0_121.jdk/Contents/Home
#make install
#cd swig/java
#make
it compiles and builds a "gdal.jar" binding file
Any help is greatly appreciated,
Gilles
Hi Gilles,
can you check the GeoServer log and the catalina.out looking for some GDAL library loading related message?
You should see one of these 2 messages (depending on loading success vs loading failure):
When successfully loaded:
GDAL Native Library loaded (version: X.X.X)
When missing:
Failed to load the GDAL native libs. This is not a problem
unless you need to use the GDAL plugins: they won’t be enabled
Does your swig build also created gdaljni, gdalconstjni, ogrjni, osrjni,… dynamic libs?
If that is the case, are them in the same location where you have installed the other libs ?
Being on a MacOS, you may need to configure the DYLD_LIBRARY_PATH on your startup scripts, referring to the path where the dynamic lib have been installed.
Hopefully, some MacOS dev may chime in to provide you additional feedbacks on this topic.
Please, let us know.
Best Regards,
Daniele
On Mon, Mar 20, 2017 at 4:51 PM, Gilles Celli <gilles.celli@anonymised.com> wrote:
Well I’m not sure if i should post that here (or on the geoserver-users mailing list), but it seems related to Geoserver development, so here we go:
We have Geoserver 2.10.1 running on macOS 10.11 but we need ENVI file support, that’s why I compiled the latest gdal 2.1.3 libraries manually
I copied the “gdal.jar” java binding file to geoserver/WEB-INF/lib/ along with imageio-ext recommended .jars files, as described here
However the ENVI format in “Raster Data Sources” is not available.
It seems that Geoserver doesn’t recognize the “gdal.jar” binding file, even if I rename it to “imageio-ext-gdal-bindings-1.9.2.jar”
( Geo-Solutions Java Binding file it is named “imageio-ext-gdal-bindings-1.9.2.jar” file in th
So my question is:
Note that I even compiled the ImageIO-Ext 1.1.7 plugin for macOS (by correcting the pom.xml files) (which I don’t think it’s required since the .jars can be downloaded from
#cd gdal-2.1.3
–with-libtiff=/Library/Frameworks/UnixImageIO.framework/unix --with-jpeg=/Library/Frameworks/UnixImageIO.framework/unix
–with-gif=/Library/Frameworks/UnixImageIO.framework/unix --with-png=/Library/Frameworks/UnixImageIO.framework/unix
–with-geotiff=/Library/Frameworks/UnixImageIO.framework/unix --with-pcraster=internal --with-geos=/Library/Frameworks/GEOS.framework/unix/bin/geos-config --with-static-proj4=/Library/Frameworks/PROJ.framework/unix
–with-expat --with-python -with-java -with-jvm-lib=/Library/Java/JavaVirtualMachines/jdk1.8.0_121.jdk/Contents/Home
#make install
#cd swig/java
#make
it compiles and builds a “gdal.jar” binding file
Gilles
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hi Daniele,
I made some progress:
By checking logs of geoserver, “gdal.jar” was missing in “geoserver/WEB-INF/lib”, I copied it then to it.
And yes the dynamic libs were built by swig in the gdal/swig/java/ as you mentioned:
#ls gdal-2.1.3/swig/java/*.dylib
libgdalconstjni.20.dylib libgdaljni.20.dylib libogrjni.20.dylib libosrjni.20.dylib
libgdalconstjni.dylib libgdaljni.dylib libogrjni.dylib libosrjni.dylib
So I copied the dynamic libs to /usr/local/lib and set the DYLD_LIBRARY_PATH in both “setenv.sh” and my ~/.bash_profile
But I sill get:
21-Mar-2017 11:52:30.973 WARNING [localhost-startStop-1] it.geosolutions.imageio.gdalframework.GDALUtilities.loadGDAL Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
From “catalina.out” log file:
21-Mar-2017 11:35:21.773 WARNING [localhost-startStop-1] it.geosolutions.imageio.gdalframework.GDALUtilities.loadGDAL Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.
21-Mar-2017 11:35:11.801 INFO [localhost-startStop-2] org.geoserver.GeoserverInitStartupListener.contextDestroyed Unregistering Image I/O provider it.geosolutions.imageio.plugins.jp2kakadu.JP2GDALKakaduImageWriterSpi@anonymised.com
21-Mar-2017 11:35:11.801 INFO [localhost-startStop-2] org.geoserver.GeoserverInitStartupListener.contextDestroyed Unregistering Image I/O provider it.geosolutions.imageio.stream.output.spi.StringImageOutputStreamSpi@anonymised.com
Any clues ?
Gilles
So my question is:
#cd gdal-2.1.3
#make install
#cd swig/java
#make
Gilles
Geoserver-devel@anonymised.comsourceforge.net
Hello Gilles
You may also need to set the -Djava.library.path java parameter to point to the location of the gdaljni files. Try adding the following to setenv.sh:
export JAVA_OPTS=“-Djava.library.path=/usr/local/lib”
Also, as a point of comparaison, I have the following GDAL dynamic libs on OS X (I am using GDAL 1.11.2):
libgdal.1.dylib
libgdal.dylib
libgdalconstjni.1.dylib
libgdaljni.1.dylib
libgdaljni.dylib
libltidsdk.9.dylib
libltidsdk.dylib
libogrjni.1.dylib
libogrjni.dylib
libosrjni.1.dylib
libosrjni.dylib
libtbb.dylib
Hope this helps,
Torben
On Tue, Mar 21, 2017 at 3:56 AM, Gilles Celli <gilles.celli@anonymised.com> wrote:
Hi Daniele,
But I sill get:
21-Mar-2017 11:35:11.801 INFO [localhost-startStop-2] org.geoserver.GeoserverInitStartupListener.contextDestroyed Unregistering Image I/O provider it.geosolutions.imageio.plugins.jp2kakadu.JP2GDALKakaduImageWriterSpi@7a22e404
21-Mar-2017 11:35:11.801 INFO [localhost-startStop-2] org.geoserver.GeoserverInitStartupListener.contextDestroyed Unregistering Image I/O provider it.geosolutions.imageio.stream.output.spi.StringImageOutputStreamSpi@35038fe5
Any clues ?
Gilles
On 21 Mar 2017, at 10:00, Daniele Romagnoli <daniele.romagnoli@anonymised.comsolutions.it> wrote:
Hi Gilles,
When missing:
Best Regards,
Daniele
So my question is:
#cd gdal-2.1.3
#make install
#cd swig/java
#make
Gilles
Geoserver-devel@anonymised.comrge.net
Here’s my quick guide on how to install and enable GDAL support for Geoserver on macOS / Mac OS X.
Enabling gdal for Geoserver with imageio-ext on macOS
Tested on Mac OS X 10.11.6 with Tomcat 8.5.12 and Geoserver 2.10.2
Pre-requirements:
Xcode developer tools; install with command:
#xcode-select --install
You have several possibilities to enable GDAL support for Geoserver on macOS:
  1. Homebrew or Macports package manager
  2. Manually compiling gdal (but you need dependencies libraries) from source
Latest “Java 8 SDK” from Oracle, download from:
http://www.oracle.com/technetwork/java/javase/downloads/index.html
Homebrew installation, see here:
https://brew.sh
Hi Daniele,
But I sill get:
Any clues ?
Gilles
Hi Gilles,
When missing:
Best Regards,
Daniele
So my question is:
#cd gdal-2.1.3
#make install
#cd swig/java
#make
Gilles
