Quick question Niels since we were discussing Resource and LockProvider the other day.
I am reviewing the goal_translate pull request, which uses a watcher to monitor a Resource for changes. Inside the code there is a read/write lock to protect access during a resource change event.
The watcher is just a short cut for looking out for resource changed events. I was wondering if the resource lock method should be used instead - the logic being that the LockProvider is configured under admin control and may be correctly configured for resource change events.
I expect the pull request is fine as written, we will need to carefully consider what order to apply event notification, resource.lock(), and code monitors or read/write locks to prevent deadlock in a clustered environment.
It would be good to highlight the use of a watcher like this, and see if it should migrate to direct ResourceListener use and if a Resource lock can be used. My rough idea is:
resource lock when writing the change
resource lock release when the event change is complete, followed by event notification to nodes in the cluster
resource listeners (including any file watchers) are notified and read the contents. If they have an internal read/write lock on the resulting data structure it should not introduce deadlock
Key to the above being successful is ensuring that code such as dal_translate does not both hold a resource lock and their data structure read/write lock at the same time.
Let me know if the above makes sense and we can highlight it in the developers guide.
Makes sense. It looks to me like the PR does use the ResourceListener rather than FileWatcher.
Ideally, the resource.lock() should also be used to have a uniform API for locking.
Regards
Niels
1. resource lock when writing the change
2. resource lock release when the event change is complete, followed by event notification to nodes in the cluster
3. resource listeners (including any file watchers) are notified and read the contents. If they have an internal read/write lock on the resulting data structure it should not introduce deadlock
Yeah. I considered making input stream wrappers that automatically used the read lock, and then released it on close(). Not sure if I did not successfully or not - you are welcome to review.
Point being that locks are involved in resource access; so me may need to look out for deadlock.
Regards
Niels
It should always be avoided to lock more than one resource at a time. Locking should only happen for a short period of time.
I agree with your proposal.
Jody Garnett
On 6 August 2015 at 04:24, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
Hi Jody,
API for locking.
Regards
Niels
change event.
introduce deadlock
It is also worth checking the out() - it uses locks and writes to a temporary file, the close() method copies the file into position once it is completely written out.
This should mirror your workflow for a JDBCConfig ResourceStore implementation.
Regards
Niels
