[Geoserver-devel] Generalized ExternalGraphicFactory caching?
I am working on an implementation of the ExternalGraphicFactory interface that supports Mapbox-style spritesheets (spec), and I have a question about image caching.
I see that the current implementation of ImageGraphicFactory caches BufferedImages and provides a resetCache() method. That method is not part of the interface – instead, GeoServer calls it directly in the WMSLifecycleHandler::onReset() method. Is that image-cache-reset functionality generalized anywhere that I am not seeing? Do we want it to be? Or, on the other hand, would it be reasonable for a style module to provide its own lifecycle handler and manage its cache that way?
Any input or feedback is appreciated.
Matt
On Fri, Mar 24, 2017 at 6:05 PM, Matt Kruszewski <
mkruszewski@anonymised.com> wrote:
<https://www.mapbox.com/mapbox-gl-js/style-spec/#sprite&gt;\), and I have a
of the interface -- instead, GeoServer calls it directly in the
Nope
That would be a good idea imho
Imho a style module should not be aware of those details, they should be
orthogonal, a graphic factory can either be used
from all styling languages, or its design is broken
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Continuing with the idea of a generalized way to reset ExternalGraphicFactory caches, would something as simple as a CachingExternalGraphicFactory interface be appropriate? Something along the lines of this branch? The GS lifecycle handler would then just reset the cache based on the interface. (I left the existing static resetCache() methods in place in this example for GeoServer’s sake).
  • Matt
On Fri, Mar 24, 2017 at 12:56 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Mar 24, 2017 at 6:05 PM, Matt Kruszewski <mkruszewski@anonymised.com> wrote:
Nope
Imho a style module should not be aware of those details, they should be orthogonal, a graphic factory can either be used
Ing. Andrea Aime
@geowolf
Technical Lead
That sounds fine Matt,
We woudl like to backport this work, so we may need to ask GeoServer 2.11.x to use reflection to call this method in order not to backport an api change.
On 13 April 2017 at 12:15, Matt Kruszewski <mkruszewski@anonymised.com> wrote:
Hi Andrea,
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
  • Matt
On Fri, Mar 24, 2017 at 12:56 PM, Andrea Aime <andrea.aime@anonymised.com1268…> wrote:
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Matt,
looks fine indeed
On Thu, Apr 13, 2017 at 7:15 PM, Matt Kruszewski <mkruszewski@anonymised.com> wrote:
Hi Andrea,
  • Matt
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Jody,
check his branch, Matt made a new sub-interface, there is no API break, just has to follow the usual rule for new features (1 month cooldown,
although this one is so small that I doubt waiting would do much good)
On Mon, Apr 17, 2017 at 2:04 AM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
Hi Andrea,
Geoserver-devel@anonymised.comrge.net
  • Matt
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I though the interface would need to be in GeoTools, which is more strict about API breaks.
On 17 April 2017 at 01:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
On Mon, Apr 17, 2017 at 2:04 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
  • Matt
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
It should go in Geotools but I still do not see what is the problem. A new optional sub-interface does not an API break make :wink:
Please clarify the issues it causes to Geotools users
Jody Garnett
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
  • Matt
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
Yep, and I prefer that to reflection.
Jody Garnett
Hi Jody,
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Andrea,
  • Matt
Nope
Ing. Andrea Aime
@geowolf
Technical Lead
