On Fri, Oct 21, 2016 at 7:45 PM, Bryan Moore <bryan@anonymised.com> wrote:
I was hoping that I was just doing something silly that could be easily corrected. If nothing turns up then I guess digging into code is the next step.
Meantime attached are files containing the failing XML, the stacktrace, and the command + output.
Bryan
On 10/21/16 1:33 PM, Andrea Aime wrote:
Hi Bryan,
the GeoServer geopackage module is currently unsupported, so the best answer to your question likely lies in fixing the code.
That said, share a request that does not work, and the GeoServer logs of the failure (from its log file, the full stack trace),
that might give us some clue as to what might be happening.
On Fri, Oct 21, 2016 at 6:21 PM, Bryan Moore <bryan@anonymised.com> wrote:
I can successfully generate a GeoPackage file from the “nurc:Arc_Sample” layer included with GeoServer but the other raster layers (nurc:Pk50095, nurc:mosaic, nurc:Img_Sample, sf:sfdem) fail.
Environment:
GeoServer v. 2.9.1, With WPS and GeoPackage extensions installed. (geoserver-2.9-SNAPSHOT-geopkg-plugin.zip, geoserver-2.9.1-wps-plugin.zip)
The attached xml file can be used successfully to ask GeoServer to create a GeoPackage file. It requests the “nurc:Arc_Sample” raster.
Executing:
curl -u admin:geoserver -H ‘Content-type: xml’ -XPOST -d@‘workingGeoPackageRequest.xml’ http://localhost:8080/geoserver/wps
Returns:
http://localhost:8080/geoserver/ows?service=WPS&version=1.0.0&request=GetExecutionResult&executionId=56ebf82e-d111-4e3f-a287-ed5870fc2487&outputId=mygeopackage.gpkg
Testing:
Put the above URL into browser and download the GeoPackage file.
Create a new Store → GeoPackage(mosaic) using the downloaded file.
Publish the layer
Preview the layer.
This works great with the nurc:Arc_Sample layer but fails with nurc:Pk50095, nurc:mosaic, nurc:Img_Sample, sf:sfdem or any of my own GeoTiff layers.
nurc:mosaic and sf:sfdem return: exceptionCode=“NoApplicableCode” Process failed during execution java.lang.NullPointerException
nurc:Pk50095 and nurc_Img_Sample return Error rendering coverage on the fast path java.lang.IllegalArgumentException: Band number 3 is not valid.
Any idea what is going wrong or can anyone create an xml file that will successfully get the GeoPackage file for any of the other raster layers.
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
