[Geoserver-devel] Geofence drag and drop and JQuery version
in GeoFence is possible to manage rules priority using drag and drop, this functionality was implemented using the library wicket-dnd (https://github.com/svenmeier/wicket-dnd).
After the Apache Wicket 7 upgrade the wicket-dnd library was also upgraded to a version that supports Apache Wicket 7, but the drag and drop functionality was not working.
Long story short, the drag and drop in GeoFence is not working because of the JQuery version used by GeoServer. Apache Wicket 7 and the wicket-dnd use JQuery 1.11.3 but GeoServer still includes JQuery 1.2.6.
To fix the drag and drop issue the version of JQuery imported by GeoServer needs to be upgraded to JQuery 1.11.3.
Looking for imports of JQuery library under geoserver/src returns the following paths:
./web/core/src/main/java/org/geoserver/web/GeoServerBasePage.html
./web/demo/src/main/java/org/geoserver/web/demo/PlainCodePage.html
./web/core/src/main/java/org/geoserver/web/wicket/CodeMirrorEditor.js
./web/core/src/main/java/org/geoserver/web/wicket/GeoServerTablePanel.html
./extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.html
None of this files is directly using JQuery for doing something, at the exception of CodeMirrorEditor all the imports of JQuery exists only because of the plugin inline-info.
Besides, in file CodeMirrorEditor the code that uses JQuery is commented.
The inline-info plugin is located in:
./web/core/src/main/java/org/geoserver/web/js/jquery.inline-info.js
and the source code for this plugin is available at:
https://github.com/chrispatterson/jquery-inline-info
This plugin is used to show tips to user directly in the input fields, when the user clicks in the input field the tip is removed allowing the user to enter the data.
Even if this plugin is imported by several files it is only used in GeoServerBasePage (to show username and password tips in the login fields) and in
GeoServerTablePanel (to show the tip Search in the filter field).
Sadly the inline-info plugin has not been updated in the last years and don't support JQuery 1.11.3.
So, if I didn't miss anything upgrading the JQuery 1.2.6 included by GeoServer to JQuery 1.11.3 can be resumed to find an alternative to the inline-info plugin.
I have tree possible solutions for this:
- Check if apache wicket 7 provides the same functionality as the inline-info plugin out of the box.
- Find a JQuery 1.11.3 plugin alternative.
- Change this inline-info plugin source to be compatible with JQuery 1.11.3 (not very difficult).
Any comments on this are welcome :slight_smile:
Best regards,
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
On Tue, Apr 5, 2016 at 7:35 PM, nuno.oliveira <
Hi Nuno,
my 2 cents on the matter, I'd go for something directly supported by
wicket7 if at all possible,
and if not, try to build a solution that works on top of the wicket7 own
jquery, instead
of adding a copy of jquery in the codebase
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thank you for the feedback Andrea.
HTML5 give us the placeholder attribute that allow us to do the same thing as the inline-info plugin JQuery plugin:
http://www.w3schools.com/tags/att_input_placeholder.asp
Basically when declaring an input field in wicket we have to provide the placeholder attribute:
The only problem is that the placeholder attribute is not supported by older versions of Internet Explorer.
So I also used a JQuery plugin that will make placeholders possible in older versions of IE but will not do
anything if the browser supports the placeholder attribute:
https://github.com/mathiasbynens/jquery-placeholder
This plugin is compatible with the JQuery version used by Apache Wicket. The plugin will use the defined
placeholder attribute so no extra configuration required. To activate the plugin we only need to add the line:
$(‘input, textarea’).placeholder();
I manually tested this solution with recent version of browsers Firefox and Chrome and with Internet Explorer 8.
I will do a pull request with this changes.
Nuno Oliveira
On Tue, Apr 5, 2016 at 7:35 PM, nuno.oliveira <nuno.oliveira@anonymised.com> wrote:
  • Check if apache wicket 7 provides the same functionality as the inline-info plugin out of the box.
  • Find a JQuery 1.11.3 plugin alternative.
  • Change this inline-info plugin source to be compatible with JQuery 1.11.3 (not very difficult).
Hi Nuno,
my 2 cents on the matter, I’d go for something directly supported by wicket7 if at all possible,
and if not, try to build a solution that works on top of the wicket7 own jquery, instead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for watching out for the older browsers. Our customer base is generally stuck multiple generations back on Firefox and Internet Explorer.
(attachments)
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
Sent: Wednesday, April 06, 2016 7:10 AM
To: Andrea Aime <andrea.aime@…1268…>
Cc: Geoserver-devel geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Geofence drag and drop and JQuery version
<input id=“username” type=“text” name=“username” value=“” title=“username” placeholder=“username”
wicket:message=“title:username,placeholder:username”/>
Nuno Oliveira
Hi Nuno,
Ing. Andrea Aime
@geowolf
Technical Lead
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Thanks for the extensive research, do we actually make use of the inline-info functionality anywhere?
When I was experimenting with providing feedback the wicket documentation indicated we could provide per field warnings - something I was unable to get to work due to “how wicket was setup in geoserver”. As a result we have any form or data entry earnings listed at the top of the page. I am sorry I do not have further details on how we got to that position.
On 5 April 2016 at 10:35, nuno.oliveira <nuno.oliveira@anonymised.com> wrote:
Sadly the inline-info plugin has not been updated in the last years and don’t support JQuery 1.11.3.
So, if I didn’t miss anything upgrading the JQuery 1.2.6 included by GeoServer to JQuery 1.11.3 can be resumed to find an alternative to the inline-info plugin.
Best regards,
Nuno Oliveira
@nmcoliveira
Software Engineer
June, 30 2003, no.196 - Italy’s New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
Geoserver-devel mailing list
Jody Garnett
On Thu, Apr 7, 2016 at 9:10 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
We do, Nuno provided that information in it's first mail:
enter the data.
and in
get to work due to "how wicket was setup in geoserver". As a result we have
inline-info does not seem to be used for error reporting. If you're eager
to work on this though, you could start a separate thread to discuss it
(let's keep this one focused if at all possible).
Ing. Andrea Aime
@geowolf
Technical Lead
The pull request for this was made:
https://github.com/geoserver/geoserver/pull/1557
Best regards,
Nuno Oliveira
We do, Nuno provided that information in it’s first mail:
inline-info does not seem to be used for error reporting. If you’re eager to work on this though, you could start a separate thread to discuss it (let’s keep this one focused if at all possible).
Ing. Andrea Aime
@geowolf
Technical Lead
