Looking at the logs, the key difference between short and long builds is trouble resolving dependencies:
[WARNING] Could not transfer metadata org.geotools:gt-api:16-SNAPSHOT/maven-metadata.xml from/to hibspat ([http://www.hibernatespatial.org/repository](http://www.hibernatespatial.org/repository)): Connection reset
[WARNING] The metadata /var/lib/jenkins/.m2/repository/org/geotools/gt-api/16-SNAPSHOT/maven-metadata-ibiblio.xml is invalid: end tag name </body> must match start tag name <hr> from line 888 (position: START_TAG seen ... 08-Nov-2014 19:04 207\r\n</pre><hr></body>... @888:18)
Commented our hibernate spatial repository, looking at the pom.xml there is a large number of repositories commented out. If it is helpful we can either upload or mirror to decrease build times.
I've re-run the jenkins job and, after your changes, it took 7 min 7 sec.
It seems there are no more delays due to dead repos.
Emanuele
I’ve re-run the jenkins job and, after your changes, it took 7 min 7 sec.
Emanuele
(http://www.hibernatespatial.org/repository): Connection reset[WARNING]
The metadata
tadata-ibiblio.xml is invalid: end tag name must match start tag
name
from line 888 (position: START_TAG seen …
08-Nov-2014 19:04 207\r\n… @888:18)
Jody Garnett
Visit http://goo.gl/NWWaa2 for more information.
