Okay, I found nothing on google but I have further debugged, as I had expected it appears the problems are not caused by lazy initialization, but by the following single line *https://github.com/geoserver/geoserver/blob/ed613876cb6aba59fd922e25fd957f18a85815a2/src/main/src/test/java/org/geoserver/test/GeoServerTestApplicationContext.java#L44**
setValidating(false);
Surprisingly turning validation off causes serious malfunctions as spring does not interpret the xml correctly.
If you look in the schema at http://www.springframework.org/schema/beans/spring-beans-3.0.xsd you find the following bean attribute definition:
<xsd:attribute name="autowire" default="default">
Now what normally happens in the spring code is that when you don't specify an autowire attribute in your bean definition, it is supposed to be set to "default" which tells spring to use the autowire attribute that has been defined for the whole context, which is in our case "byname".
Without validation the xsd isn't processed and the default is apparently ignored, causing autowire to be an empty string for each bean instead of the string "default". The spring code cannot handle this empty string and reverts to no autowiring.
It's a bit dodgy that spring works that way, but apparently it does so. Note that other problems may occur as well because there are other attributes with default values.
I would recommend removing that line altogether since it seems a malfunction to me. Otherwise it must at least be made optional somehow because at this point it is already too late to change when oneTimeSetUp is run in my derived class.
Regards
Niels
On 22-05-15 13:51, Andrea Aime wrote:
On Fri, May 22, 2015 at 1:23 PM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
For all clarity, with geofence modules I was talking about the
actual *geofence* backend modules themselves, not the community
modules in geoserver. Because the problem concerns beans declared
in geofence itself, not the community modules. So this would mean
geofence itself needs to be changed.
I don't think the problem has anything to do with beans having
effects that change the environment. The problem is very clearly
that 'default-autowire="byName" is not working any longer for any
context that is loaded. I have confirmed this. Is this a desired
or accidental effect of your changes? Because geofence relies on
autowire byname.
The thing is, I never used autowiring, so I don't know. A generic search on the internet might help though.
Also, it should be fairly easy to add a method to GeoServerSystemTestSupport that
forces GeoServerTestApplicationContext not to use lazy loading for test that cannot handle it.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
