I am not quite sure on how we manage the geofence project, from the README I should take developer questions here.
I would like to start a spring-4-upgrade branch, coordinating with any interested developers here.
The geofence codebase is split up into two projects, each with their own set of properties controlling version numbers:
src/gui.pom.xml
src/services/pom.xml (has model and services-api as children)
I am not sure of the advantage of duplicating here, it does allow the codebase to produce two distinct projects with slightly different dependencies.
On the geoserver side the spring-4-upgrade branch has:
org.geoserver.geofence geofence-services-api ${gf.version} org.geoserver.geofence geofence-model ${gf.version}community/geofence-server/pom.xml
org.geoserver.geofence geofence-services-impl ${gf.version}–
Jody Garnett
Jody Garnett
Hi Jody,
I'm starting giving a look to the GeoFence migration to spring4.
More on this once I understand better how much this upgrade will impact on the
existing code and deps.
Emanuele
I should take developer questions here.I would like to start a spring-4-upgrade branch, coordinating with any
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
mob: +39 380 2116282
Thanks Emanuele, Kevin and I have some time to help out - if we can be of assistance.
I would like to merge the geoserver and geowebcache spring-4-update branches to master, can we do so today or will that disrupt your plans?
On 22 March 2016 at 03:34, Emanuele Tajariol <etj@anonymised.com> wrote:
Hi Jody,
I’m starting giving a look to the GeoFence migration to spring4.
existing code and deps.Cheers,
interested developers here.–
Visit http://goo.gl/NWWaa2 for more information.Ing. Emanuele Tajariol
Technical LeadGeoSolutions S.A.S.
mob: +39 380 2116282http://www.geo-solutions.it
Jody Garnett
I created a branch for the porting of GeoFence to Spring 4.
You can find it here:
https://github.com/geoserver/geofence/tree/3.1-spring4
I also committed some changes to the community modules to allow them to build
properly:
https://github.com/geoserver/geoserver/commit/6014433cbe2fe2eeff2f4081863526ed1be8ca34
The normal build completes successfully, but the integration tests
(https://github.com/geoserver/geofence/wiki/Devs%3A-running-integration-tests)
tell that the REST module is broken.
The integration tests with geoserver (which tests the AccessManager performing
requests to geofence) are ok, but I have yet to test a real integration
running.
Posting news as soon as they are available.
Emanuele
Alle 11:34:52 di Tuesday 22 March 2016, Emanuele Tajariol ha scritto:
Hi Jody,
the existing code and deps.Cheers,
Technical Lead
Just committed a fix for that. It seems that the @Produces annotations are a
bit more picky now.
Emanuele
Alle 13:58:54 di Wednesday 30 March 2016, Emanuele Tajariol ha scritto:
https://github.com/geoserver/geofence/tree/3.1-spring4I also committed some changes to the community modules to allow them to
build properly:
26ed1be8ca34The normal build completes successfully, but the integration tests
ts) tell that the REST module is broken.The integration tests with geoserver (which tests the AccessManager
performing requests to geofence) are ok, but I have yet to test a real
integration running.Posting news as soon as they are available.
EmanueleAlle 11:34:52 di Tuesday 22 March 2016, Emanuele Tajariol ha scritto:
> Hi Jody,
> on the existing code and deps.
> Cheers,
> Emanuele
Technical Lead
That is great Emanuele, hunting down your commit so we can all learn from it:
On noes - you placed the commit on the spring-4-upgrade branch which has now been merged to master.
Fix spring4 porting for geofence community modules
Can you apply this fix to master and we can delete the spring-4-upgrade branch.
bit more picky now.Cheers,
EmanueleAlle 13:58:54 di Wednesday 30 March 2016, Emanuele Tajariol ha scritto:
build properly:https://github.com/geoserver/geoserver/commit/6014433cbe2fe2eeff2f40818635
Hi Jody,
on the existing code and deps.Cheers,
README I should take developer questions here.I would like to start a spring-4-upgrade branch, coordinating with any
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785471&iu=/4140
Geoserver-devel mailing list
Jody Garnett
branch.
Sure,
here it is
<https://github.com/geoserver/geoserver/commit/9473b585770f068ec0c1374e68f19ddb13d8e8ef>
Emanuele
it:On noes - you placed the commit on the spring-4-upgrade branch which has
now been merged to master.Fix spring4 porting for geofence community modules
<https://github.com/geoserver/geoserver/commit/6014433cbe2fe2eeff2f40818635
26ed1be8ca34>Can you apply this fix to master and we can delete the spring-4-upgrade
branch.--
Jody GarnettOn 30 March 2016 at 07:43, Emanuele Tajariol <etj@anonymised.com> wrote:
> are a
> bit more picky now.
> Cheers,
> Emanuele
> > Hi,
> > build properly:
> 5
> > 26ed1be8ca34
> s
> > Cheers,
> > Emanuele
> > > Hi Jody,
> > > impact on the existing code and deps.
> > > Cheers,
> > > Emanuele
> any
Technical Lead
branch.Sure,
here it is
Emanuele
The geoserver-master build now fails because the corresponding changes in the geofence 3.1-spring4 branch have not yet been merged:
Build failure:
http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2346/changes
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Uhm... quite a big change anyway....
I wonder if it's the case to bump to version 3.2 for geofence.
Definitely we need a strategy for keeping the versions of GeoServer and
GeoFence somehow aligned.
Emanuele
>> branch.
> Sure,
> here it is
> f19ddb13d8e8ef>
> Cheers,
> EmanueleThe geoserver-master build now fails because the corresponding changes
https://github.com/geoserver/geofence/tree/3.1-spring4Build failure:
http://ares.boundlessgeo.com/jenkins/job/geoserver-master/2346/changesKind regards,
Technical Lead
https://github.com/geoserver/geofence/tree/3.1-spring4Uhm... quite a big change anyway....
I raised this issue when I noticed the snapshot dependency last year:
http://osgeo-org.1560.x6.nabble.com/a-bit-stuck-on-2-9-M0-release-td5242228.html
Jody wrote: "we do not need to stress until the beta :)". The beta is passed and beta2 approaches. Turn that smile upside down.
We could build geofence releases into our release plan, which would allow more easy tracking of snapshots (like geowebcache), or you could make a geofence (for example) 3.1.0 release and the GeoServer community geofence modules could then depend on it. How often does geofence change? How active is development?
Kind regards,
Director
New Zealand
- branched geofence 3.1.x (Geoserver 2.8 depends on it)
- merged the spring4 branch onto master
- bumped geofence master to 3.2-SNAPSHOT
- fixed the geofence deploy on ares (the jenkins job was not deploying the
artifacts )
- bumped the geofence dep on geoserver to 3.2-SNAPSHOT
Jenkins seems to be quite satisfied at the moment for both geofence-master and
geoserver-master
Emanuele
I wonder if it's the case to bump to version 3.2 for geofence.Definitely we need a strategy for keeping the versions of GeoServer and
GeoFence somehow aligned.Cheers,
> > Sure,
> > here it is
> > 68 f19ddb13d8e8ef>
> > Cheers,
> > Emanuele
> Build failure:
> Kind regards,
Technical Lead
Thanks, Emanuele. We will probably need a release of geofence for GeoServer 2.9-beta2 and later releases. I am not sure how strict we should be with community module dependencies. The committee should discuss at the meeting next week.
Kind regards,
Ben.
On 01/04/16 00:46, Emanuele Tajariol wrote:
artifacts )
- bumped the geofence dep on geoserver to 3.2-SNAPSHOTJenkins seems to be quite satisfied at the moment for both geofence-master and
geoserver-masterCheers,
Emanuele
Director
New Zealand
When you say “quite satisfied” - do you mean mean it builds, or have you been in position to test. I am updating the wiki page and would like to know if the two geoserver community modules simply build, or if they pass tests.
On 31 March 2016 at 04:46, Emanuele Tajariol <etj@anonymised.com> wrote:
artifacts )- bumped the geofence dep on geoserver to 3.2-SNAPSHOT
https://github.com/geoserver/geofence/tree/3.1-spring4Uhm… quite a big change anyway…
I wonder if it’s the case to bump to version 3.2 for geofence.Definitely we need a strategy for keeping the versions of GeoServer and
spring-4-upgrade branch.Sure,
here it is
68 f19ddb13d8e8ef>Cheers,
Jody Garnett
At the time I wrote the mail, I was only referring to Jenkins building and
running tests successfully.
We then performed some manual testing, both with GeoFence standalone, and with
the embedded version, and both are behaving as they should.
Emanuele
Alle 18:38:33 di Tuesday 5 April 2016, Jody Garnett ha scritto:
When you say "quite satisfied" - do you mean mean it builds, or have you
tests.--
Jody GarnettOn 31 March 2016 at 04:46, Emanuele Tajariol <etj@anonymised.com> wrote:
> Hi,
> the
> artifacts )
> geofence-master and
> geoserver-master
> Cheers,
> Emanuele
> > Cheers,
> > Emanuele
> > > > Sure,
> > > > here it is
> > > > 68 f19ddb13d8e8ef>
> > > > Cheers,
> > > > Emanuele
> > > Build failure:
> > > s
> > > Kind regards,
> Technical Lead
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> ----- Transform Data into Opportunity.
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Technical Lead
Dear Jody,
we have done also done a decent extent of manual testing.
There is one thing which is pending, after the wicket upgrade we lost
the drag and drop functionality for the geofence intergated GUI but we
want it back asap but it's tricky.
One of our guys, Nuno will follow up shortly on this (it will open a
separate thread).
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Apr 5, 2016 at 6:38 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
if the two geoserver community modules simply build, or if they pass tests.--
artifacts )
and
> Cheers,
> Emanuele
> > > Sure,
> > > here it is
> > > 68 f19ddb13d8e8ef>
> > > Cheers,
> > > Emanuele
> > Build failure:
> > Kind regards,--
http://twitter.com/geosolutions_it-------------------------------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-devel------------------------------------------------------------------------------
Thank you! Updating the wiki page based on your email - makes me feel like we are a lot closer.
running tests successfully.We then performed some manual testing, both with GeoFence standalone, and with
the embedded version, and both are behaving as they should.Cheers,
tests.–
theartifacts )
geofence-master and
here it is
68 f19ddb13d8e8ef>
sKind regards,
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Jody Garnett
Hi Jody,
speaking of closer, what’s the status of the other manual testing?
Is there anything else you could use a helping hand on?
E.g., CAS, LDAP against active directory?
On Tue, Apr 5, 2016 at 7:07 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
tests.–
theartifacts )
geofence-master and
here it is
68 f19ddb13d8e8ef>
sKind regards,
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Emanuele,
we discussed the GeoFence SNAPSHOT dependency at today's committee meeting. As the GeoServer modules are community modules, there is no prohibition on SNAPSHOT dependencies, but we recommend using release dependencies to improve reproducibility and maintainability. Would you consider making a (for example) GeoFence 3.2.0 release and updating the GeoServer modules to depend it before GeoServer 2.9-beta2?
Kind regards,
Ben.
discuss at the meeting next week.Kind regards,
Ben.On 01/04/16 00:46, Emanuele Tajariol wrote:
artifacts )
Emanuele
Director
New Zealand
Hi Ben,
Would you
Sure, will do.
Emanuele
Alle 22:27:54 di Tuesday 5 April 2016, Ben Caradoc-Davies ha scritto:
Emanuele,
GeoServer modules to depend it before GeoServer 2.9-beta2?Kind regards,
> Kind regards,
> Ben.
Technical Lead
