[Geoserver-devel] GeoFence users encrypt key
Hello,
I was looking at decrypting externally a users database managed by GeoFence and I found this:
https://github.com/geoserver/geofence/blob/master/src/services/core/model/src/main/java/org/geoserver/geofence/core/model/util/PwEncoder.java#L25
https://github.com/geoserver/geofence/blob/master/src/services/core/persistence/src/main/java/org/geoserver/geofence/core/dao/util/PwEncoder.java#L26
Am I missing something or this is highly insecure? Anyone gaining access to the database has access to all the passwords instantly, right?
If so, would it work to simply replace it with this?
private static final byte KEY;
static {
String strKey = System.getProperty(“GEOFENCE_PWENCODER_KEY”);
if (strKey == null) {
strKey = “installation dependant key needed”;
KEY = strKey.substring(0, 16).getBytes();
Víctor.
Víctor González
http://geomati.co
Hi Victor,
Well, not "instantly" because they are not clear text, but anyway easily
decodable.
The lines of code you linked were indeed a reminder to make that key
customizable.
Anyway we're moving toward having GeoFence integrated into GeoServer, and in
such enviroment GF uses GS users set, where the beans involved with this
security issue are not used.
Please feel free to provide a PR to fix this issue.
   Emanuele
Alle 13:12:27 di Wednesday 12 October 2016, Víctor González ha scritto:
Hello,
and I found this:
  static {
    String strKey = System.getProperty("GEOFENCE_PWENCODER_KEY");
      strKey = "installation dependant key needed";
Víctor.
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
mob: +39 380 2116282
