Hi Gabriel,
there is discussion to discontinue the module from GeoNode as well.
That said, I am +0 to remove it but as Andrea said it is unsupported
by definition so it's your choice.
I personally prefer to see less code but supported.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Tue, Apr 30, 2019 at 1:46 PM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
yeah, let's keep it then. After I hit send I recalled geonode uses it (which is weird in its own way but I'll refrain from complaining here).
Thanks for the quick reply.
Gabriel
El mar., 30 de abr. de 2019 a la(s) 05:00, Andrea Aime (andrea.aime@anonymised.com68...) escribió:
Hi Gabriel,
community modules are by definition unsupported, and don't get their tests run (build breaking privilege is for modules
with someone behind the wheel).
Typically a module stays there in the hope of raising some interest, sometimes even for years, as long as it does not
break the build with a compile failure, at which point it gets removed from the "communityRelease" profile.
Even in that case, we normally keep the module around for a while, some might come out and resurrect it (it happened
systematically after big sprints that made heavy changes to the code base).
Personally I have no stake in the module, so I would not notice if it's gone or not, but I'd give a chance anyways?
No strong opinion, if the majority would like to see it gone or just nobody cares, by all means, lets remove it.
On Tue, Apr 30, 2019 at 1:48 AM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
As far as I know there's no one working or going to work on the current geogig community module.
I'm not sure if there's a policy to retire community modules where the company behind it shows no more interest and doesn't actively retire it.
In any case I'd like to call for retirement of the geogig community module, in the interest of keeping geoserver's code base focused on active and supported modules and avoid cluttering.
Opinions? objections?
Gabriel Roldán
Geoserver-devel mailing list
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Gabriel Roldán
