[Geoserver-devel] GeoGig repository not accessible, breaking (at least) Travis builds
it seems the locationtech repository hosting the GeoGig snapshots is not reachable and
this is affecting Travis builds, making them fail in the “community modules” part of the build:
https://repo.locationtech.org/content/repositories/geogig/
Checked locally, it’s unreachable, and verified with a third party too:
Anyone knows if this is just a temporary problem?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Looks like it was temporarily down.
In any case I’ll try to get rid of the locationtech repository and tie the plugin only to a released version from maven central.
Gabriel.
(attachments)
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
