On Mon, Mar 2, 2015 at 9:37 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Hi Jody,
Thanks. For community module additions, should I be submitting PRs or
just updating my little slice of the community directory?
Normally the first contribution is done as a PR, if it's fine, and you
have read the developer guide and say so,
and so on, you normally get commit access in order to maintain your
community module.
If instead the PR is a long back and forth and/or you start questioning the
way the project does things
before even having commit access... uh... things might get long
(mind, not saying you are going to do that, or that you have done anything
like that so far, because
you did not, just exemplifying for the readers what might give us doubts
about giving out commit access)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
