[Geoserver-devel] geonetwork sync solutions
Hello,
I am looking in to the different ways to synchronise metadata between geonetwork and geoserver. The only possible way I can find is using harvesters, either from the CSW of geoserver or the OGC services directly. The issue with that is that this makes it impossible to edit the records in geonetwork (even if you forced this, it would be removed with the next harvest), which means in practice that you are limited to the metadata fields that exist in geoserver.
I was wondering if there are any solutions already in existence for situations where you do want to keep your metadata in sync, but still want to take advantage of the additional fields in geonetwork (for example, upload related files to geonetwork). I see two possible ways this could be done:
(1) sync only the fields that exist in geoserver, and leave the rest untouched in geonetwork.
(2) sync from geonetwork to geoserver rather than the other way around
This might lead to some new development in geoserver, so I am also wondering, if there is any solution for this problem that could be to benefit of others?
Thanks for your advise.
Kind Regards
Niels
Hi Niels,
I guess that (1) could be the best solution. GeoNetwork is strongly targeted
at manipulating XML documents, so I guess that the metadata merging should be
done by it.
When GN harvests a resource from an WxS service, it uses an XSL for
transforming the resource returned by the WxS service into a 19139 metadata.
What could be implemented quite easily in GN is, during the harvesting,
creating an XML document holding both the old metadata (if it exists) and the
fresh harvested resource metadata, and then transform this new XML with the
XSL.
The XSL can then be customized so that the output XML (the ISO19139 record
that will be saved into GN) will be created taking info from both the old
metadata (probably the info that you know have been edited in GN, bc the WxS
service does not handle them) and from the harvested resource.
Just my 2¢.
   Emanuele
Alle 11:02:10 di Wednesday 8 March 2017, Niels Charlier ha scritto:
Hello,
this could be done:
benefit of others?
Kind Regards
Niels
--- Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
Geoserver-devel mailing list
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
mob: +39 380 2116282
Emanuele,
Thanks for your tip. That makes a lot of sense.
A downside to this scenario is that if changes need to be made, for some fields they need to happen in geoserver (if they exist there, because in geonetwork they will be overwritten) while for others they need to happen in geonetwork (if they don't exist in geoserver).
A third alternative I didn't mention yet, is to expand the metadata possibilities of geoserver. We already have a metadata map for resources with unlimited metadata fields written in the catalog, and the ability to map them to the internal CSW. All that is missing really is a GUI for this. A geoserver plugin could add an extra tab page to the layers where additional metadata fields can be edited. A configuration file would specify which additional fields should be exposed and what their type is (file, url, etc...). All of these fields can then be harvested by geonetwork through CSW.
Regards
Niels
On 08-03-17 19:33, Emanuele Tajariol wrote:
Hi Niels,
done by it.
XSL.
Just my 2¢.
    Emanuele
Hello,
this could be done:
benefit of others?
Kind Regards
Niels
Yep, I'd love to see that. Maybe with some configuration file to lay out
the editing UI... there are several examples around, one example here:
https://geopaparazzi.github.io/geopaparazzi/forms.html
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
