[Geoserver-devel] geopackage datastore missing from nightly?
Hi Devs,
can somebody confirm?
according to: http://docs.geoserver.org/latest/en/user/community/geopkg/
I should be able to view a 'geopackage' item in the add data store page
after installing WPS extension.
I downloaded nightly (I'm on Debian testing, OpenJDK Runtime Environment
(build 1.8.0_121-8u121-b13-3-b13) here).
Downloaded WPS extension and unzipped jars in
webapps/geoserver/WEB-INFO/lib dir
and restarted geoserver jetty via startup.sh
I see a WPS 1.0.0 in Service Capabilities, but I do NOT see a Geopackage
possibility as store to add as you see
http://docs.geoserver.org/latest/en/user/community/geopkg/input.html#adding-a-geopackage-vector-data-store
Do I miss something?
Or did I hit an issue?
Richard Duivenvoorde
You also need the geopackage plugin - http://ares.opengeo.org/geoserver/master/community-latest/geoserver-2.11-SNAPSHOT-geopkg-plugin.zip
The manual page is misleading though - I’ll update it.
Ian
On 11 March 2017 at 12:12, Richard Duivenvoorde <rdmailings@anonymised.com.3975…> wrote:
Hi Devs,
I should be able to view a ‘geopackage’ item in the add data store page
I downloaded nightly (I’m on Debian testing, OpenJDK Runtime Environment
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ian Turton
The manual page is misleading though - I'll update it.
Ah, thanks, yep. I see, sorry diagonal reading of the docs indeed...
Just works!
In our quest to make gpkg a default open data format... should it not be
in core instead of extenstion? Or is it just not stable enough?
One thing: why not browse to a gpkg file (just like a shp) instead of
giving a file:///home/richard/geodata/foo.gpkg url and no
password/usernamen etc?
Richard
On Sat, Mar 11, 2017 at 1:40 PM, Richard Duivenvoorde <rdmailings@anonymised.com.>
Just switched from community to extension in geotools as a store, the
geoserver output
formats need serious love imho before getting into
extension. If the current module is split into four parts, I believe the
various bits could
move at different speeds:
   - As a data store: as I see it, could be extension today with some UI
   work
   - As a WFS output format, needs some more testing but does not look that
   bad, could be extension material soon
   - As a WMS output format... imho some serious work is needed here (there
   was a thread about this months ago)
   - As a WPS process... unsure, did not look into it
For the file browser, because that requires a custom user interface to be
built for it, like we have it for shapefiles.
The username/password do require some underlying work in the datastore
implementation (hopefully not mutch,
it seems it's half implemented, but not reachable from the datastore
factory).
Long story short, to get to core it needs more investment first, and then
time and proven significant and succesfull
user base later.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
