[Geoserver-devel] GeoPackage Extension Community Module - Issue with axis order
Perhaps flipping the coordinates in GeoPackage is a variation of flipping that happens for example with shape-zip. See a bug report originally from year 2009 https://osgeo-org.atlassian.net/browse/GEOS-2397.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime <andrea.aime@…6887…>
Lähetetty: torstai 28. lokakuuta 2021 18.43
Vastaanottaja: Andreas Matheus / Secure Dimensions <am@…6690…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GeoPackage Extension Community Module - Issue with axis order
On Thu, Oct 28, 2021 at 3:40 PM Andreas Matheus / Secure Dimensions <am@…6690…> wrote:
Hello everyone,
Is there a maintainer for the GeoPackage Extension Community Module?
https://docs.geoserver.org/stable/en/user/community/geopkg/output.html
Not really, though I have been working on it (on contract), so I have passing familiarity with it.
It looks like there is an issue with AXIS ORDER for WKB when creating a GeoPacakge out of a WFS request using CRS EPSG:4326.
If you are using a WFS 1.1 or 2.0 request, then it would be normal that it produces geometries in lat/lon order, and that would
be reflected in the generated GeoPackage (it just dumps what it gets). I’d expect the WKT in the crs table to reflect the order though.
In GeoServer you get what you asked for, there are no format specific exceptions
(has been debated, but in the end, there is no funding to address it anyways.
I’ve read that Community plugins are not part of the official GeoServer software stack. So I wonder what the best way might be to report the bug on this plugin?
Use Jira anyways. But first let’s see if it’s really a bug.
Considering that I could provide a bugfix for consideration, what would be the best approach?
Make a pull request
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
