[Geoserver-devel] GEOS-1815
Hi Justin,
about <http://jira.codehaus.org/browse/GEOS-1815&gt;, I wonder if it means:
a- ensuring the responses are encoded in the globally configured geoserver
charset
b- ensuring the http response header for the charset encoding is set
or both.
I guess both, as the issue does not tell just wanted to make sure.
Gabriel
Hi Gabriel,
I actually meant to assign this to myself... must have slipped. But if you want to take it by all means be my guest :).
So yeah... I think I meant more a), but b) is very much valid too. Although I think the dispatcher may already ensure that b) is done.
-Justin
Gabriel Roldán wrote:
Hi Justin,
a- ensuring the responses are encoded in the globally configured geoserver charset
or both.
Gabriel
!DSPAM:4007,47e9335b39651336712104!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
On Tuesday 25 March 2008 06:35:07 pm Justin Deoliveira wrote:
Hi Gabriel,
np, it was cholmes choice.
Yeah, it seems for b we're covered by Dispatcher.
So it lays down to check every xml response in every service sets the
encoding, right?
cheers,
Gabriel
-Justin
> Hi Justin,
> geoserver charset
> or both.
> Gabriel
Hi Gabriel,
So it lays down to check every xml response in every service sets the encoding, right?
Hum ,in the 1.5.x code some of the XML transformer had the charset
encoding set as a property, so maybe it's not just the dispatcher
that needs it?
See for example:
http://svn.codehaus.org/geoserver/branches/1.5.x/geoserver/wfs/src/main/java/org/vfny/geoserver/wfs/responses/GML2FeatureResponseDelegate.java
line 139:
transformer.setEncoding(request.getWFS().getGeoServer().getCharSet());
