Hi Justin,
I have attached a patch for http://jira.codehaus.org/browse/GEOS-3143 re: DescribeFeatureType for complex types.
I would appreciate if you can take a look at it.
The only file changed in the core code is FeatureTypeSchemaBuilder.
Thank you
Rini
Patch reviewed, see comments in JIRA.
-Justin
Rini.Angreani@anonymised.com wrote:
Hi Justin,
I would appreciate if you can take a look at it. The only file changed in the core code is FeatureTypeSchemaBuilder.
Thank you
Rini ------------------------------------------------------------------------------
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
