Hi All,
As discussed on IRC the other day I have completed and committed the tests
sets for worldwind format outputs:
DDS test borrows from the GIF output test and extends
defaultmapproducertest. I would like the defaultmapproducertest to be more
generic and have less "image/gif" hardcoded bits. But that's just me. I
solved the issues mostly with copy-paste and replace.
The BilTest borrows from the getfeatureinfo test (thanks for the pointers
andrea) and checks that datablocks of certain byte size are returned
depending on the request i.e. byte , short and float. Also requests larger
than 512x512 generate a serviceexception. This output format essentially
misuses a WMS as a WCS since worldwind says that's how things should be.
I would like to get the module promoted to standard extension status. Thanks
for all your advice and help.
what_nick.
View this message in context: http://old.nabble.com/-GEOS-3586--BIL-DDS-MapProducer-Unitests-completed-tp26297466p26297466.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
