Hi Baskar,
I think you are on the right track with your patch. However patches are much easier to review if they are in diff/patch format. If you could provide it that way it would make review much easier.
On Wed, Sep 22, 2010 at 9:55 PM, Baskar Dhanapal <dbaskar@anonymised.com> wrote:
I am still facing this scale dependencies problem. I have been waiting for
long time to get help from anybody.Did anybody in developer list have time
to suggest on the patch that i pasted below to solve the problem.
Baskar
Baskar Dhanapal wrote:
I tried to fix this problem by adding the following code in
“KMLTransformer.java”, exactly next to scaleDenominator calculation.
for(int i =0;i<layers.length;i++) {
MapLayer layer = layers[i];
FeatureSource <SimpleFeatureType, SimpleFeature>
featureSource;
featureSource = (FeatureSource<SimpleFeatureType,
SimpleFeature>) layer.getFeatureSource();
SimpleFeatureType featureType = featureSource.getSchema();
FeatureTypeStyle featureTypeStyles =
KMLUtils.filterFeatureTypeStyles(layer.getStyle(),
featureType);
if ((featureTypeStyles == null) ||
(featureTypeStyles.length == 0)) {
break;
for(int j=0;j<featureTypeStyles.length;j++){
FeatureTypeStyle featureTypeStyle =
featureTypeStyles[j];
Rule rules = featureTypeStyle.getRules();
if ((rules == null) || (rules.length == 0)) {
break;
for(int k=0;k<rules.length;k++){
Rule rule = rules[k];
if(Math.round(scaleDenominator)>rule.getMaxScaleDenominator()){
LOGGER.log(Level.FINE, “Scale goes out of
Dependency”);
return;
As per Andreas suggestion, I am checking the calculated value against
value specified in SLD file and if it goes out, then
simply returning by ingnoring the rules.
Before adding this code the request hangs up. After adding above code the
execution completes.
I am not sure wheather the approach is correct or not, and also
“KMLTransformer.java” is a right place to keep the code.
I am dealing with vector data in Geoserver 2.0.0.
Any idea from anybody would be appreciated.
Regards
Baskar
View this message in context: http://old.nabble.com/-jira–Created%3A-%28GEOS-3843%29-KML-output-does-not-respect-scale-dependencies-in-SLD-tp27796644p29785874.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
Please let me know how can i submit patch with required format? I never
submitted any patch till now. I think i need to log in and attach this code
in GEOS-3843 directly. Please suggest.
Justin Deoliveira-6 wrote:
Hi Baskar,
much
<dbaskar@anonymised.com>wrote:
for
time
Baskar
> Hi,
> "KMLTransformer.java", exactly next to scaleDenominator calculation.
> featureSource;
> featureType);
> break;
> break;
> LOGGER.log(Level.FINE, "Scale goes out of
> Dependency");
> return;
> <maxScaleDenominator> value specified in SLD file and if it goes out,
then
the
> "KMLTransformer.java" is a right place to keep the code.
> Regards
> Baskar
http://old.nabble.com/-jira--Created%3A-(GEOS-3843)-KML-output-does-not-respect-scale-dependencies-in-SLD-tp27796644p29785874.html
Justin Deoliveira
View this message in context: http://old.nabble.com/Re%3A-(GEOS-3843)-KML-output-does-not-respect-scale-dependencies-in-SLD-tp29819529p29824876.html
http://geoserver.org/display/GEOSDOC/Creating+a+Patch has details on how to create a patch. Attaching the created patch to the jira issue would be great.
best regards,
Chris
On 9/28/10 9:27 AM, Baskar Dhanapal wrote:
Justin,
Hi Baskar,
much
for
time
Baskar
FeatureSource<SimpleFeatureType, SimpleFeature>
featureSource;
featureType);
break;
break;
Dependency");
return;
then
the
Regards
Baskar
Justin Deoliveira
Did anybody have time to look at the patch i submitted some time ago.
Baskar
View this message in context: http://old.nabble.com/Re%3A-(GEOS-3843)-KML-output-does-not-respect-scale-dependencies-in-SLD-tp29819529p30045698.html
