Hi everyone,
While committing my patches for
http://jira.codehaus.org/browse/GEOS-4683, I broke the build. This was
resolved fairly quickly (note to self - run maven just like hudson
does) but made me realize these changes were worth a heads up to
anyone authoring OWS Response subclasses.
For details see the OWS Dispatcher and the Response javadoc, but the
gist is that previously each Response subclass was handling
Content-Disposition headers via the getHeaders method. The new
behavior is that the Dispatcher uses the new API to determine a
filename, and if not null, the preferred disposition type (attachment
or the default, inline). If the request provides the
content-disposition header parameter (either inline or attachment with
header injection checking) then this is respected over the Response
preference.
I handled most of the Response subclasses and the tests. This is a
heads up for existing maintainers on the changes as well as for new
implementations.
On a related note, it is not clear whether the filename should be
quoted or encoded, but this patch will at least make that
cross-cutting concern easier to address at some point (though it
requires a number of test case adjustments).
Thanks for bearing with me and comments much appreciated,
-Ian
Ian Schneider
OpenGeo - http://opengeo.org
On Wed, Jul 27, 2011 at 4:58 AM, Ian Schneider <ischneider@anonymised.com> wrote:
I don't believe it needs to be quoted or encoded, but care should
be taken so that it only includes chars that can be used on
any filesystem. E.g. ":" is valid under unix but not on windows.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Ian,
So are you saying that the change is backward compatible with existing Responses/output formats that use getHeaders() to set the content dispotiion. Looking at the patch (and maybe I am not looking close enough) it seems like the new api will overwrite in the case where the client specifies the content-disposition flag?
Excuse the noise if i am missing something.
On Tue, Jul 26, 2011 at 8:58 PM, Ian Schneider <ischneider@anonymised.com> wrote:
Hi everyone,
preference.
implementations.
-Ian
Ian Schneider
Got Input? Slashdot Needs You.
Take our quick survey online. Come on, we don’t ask for help often.
Plus, you’ll get a chance to win $100 to spend on ThinkGeek.
http://p.sf.net/sfu/slashdot-survey
Geoserver-devel mailing list
Justin Deoliveira
Hey Justin,
In the case you mention, it is mostly backwards compatible - the
original preferred headers are respected if the Response returns null
from getAttachmentFileName. This has to be implemented in the Response
subclass, though, since the default is to compute a filename based on
operation and mimetype. The latter could be changed, but it seemed
like a balance between getting useful default behavior or preserving
the old behavior - which in almost all of the cases was trivial to
upgrade. In other words, change the Response base class behavior to
opt-in versus opt-out.
As for the client overriding the preferred type (or headers via old
API), that was the intention of the changes.
On Wed, Jul 27, 2011 at 9:11 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Ian,
wrote:
Hi everyone,
preference.
implementations.
-Ian
Ian Schneider
Take our quick survey online. Come on, we don't ask for help often.
Plus, you'll get a chance to win $100 to spend on ThinkGeek.
Justin Deoliveira
Ian Schneider
Hmmm… not sure I agree. I tend to always prefer 100% backward compatibility when its possible. I know in GeoServer we don’t publish formal api at all but the output format is the one that is most commonly implemented. So I think updating the api should not be taken lightly.
What about having the dispatcher check the result of Response.getHeaders() and if the content-disposition header was specified there don’t worry about calling the specific methods to try and determine it?
On Wed, Jul 27, 2011 at 9:52 AM, Ian Schneider <ischneider@anonymised.com> wrote:
Hey Justin,
Hi Ian,
wrote:
Hi everyone,
preference.
implementations.
-Ian
Ian Schneider
Justin Deoliveira
Ian Schneider
Justin Deoliveira
Hey Justin,
I'm not sure I understand what you don't agree with
As for implementing the check for the headers, this seems like a
reasonable approach, though at least for code in the tree, only one
implementation remains that uses the headers. I hesitate here because
it involves more dispatcher code that will mostly not be used.
The other approach I offered was to make the default implementation
opt-out of the new behavior (100% backwards compatible) and adjust the
current implementors to opt-in (remove getHeaders implementation and
use the new API).
We _do_ agree that the current solution is not optimal for out-of-tree
Response subclasses, 100% backwards compatibility is to be strived
for, and that changes to the API should not be taken lightly.
-Ian
On Wed, Jul 27, 2011 at 2:58 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hmmm... not sure I agree. I tend to always prefer 100%
backward compatibility when its possible. I know in GeoServer we don't
lightly.
and if the content-disposition header was specified there don't worry about
wrote:
Hey Justin,
wrote:
> Hi Ian,
> enough)
> wrote:
>> Hi everyone,
>> preference.
>> implementations.
>> -Ian
>> Ian Schneider
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> Justin Deoliveira
Ian Schneider
Justin Deoliveira
Ian Schneider
Hey Ian,
On Wed, Jul 27, 2011 at 4:23 PM, Ian Schneider <ischneider@anonymised.com> wrote:
Hey Justin,
I’m not sure I understand what you don’t agree with
Just that a “mostly backward compatible” approach will suffice when a completely backward compatible one is possible. Not saying you were advocating for that so “don’t agree” was poor phrasing on my part.
As I said output formats are the most common way that geoserver is extended so “out of tree” implementations should be considered. During my time people trying to implement custom output formats have come up a number of times… I imagine many of them don’t get contributed back, often with good reason because they are very custom in nature. So I generally operate under the assumption that there lots of them out there.
use the new API).
Right, which is why I think opting out of the new behaviour (by not calling the new methods) iff the header has been set by getHeaders() is a reasonable middle ground.
We do agree that the current solution is not optimal for out-of-tree
-Ian
lightly.
wrote:
Hey Justin,
wrote:
Hi Ian,
enough)
wrote:
Hi everyone,
preference.
implementations.
-Ian
Ian Schneider
Justin Deoliveira
Ian Schneider
Justin Deoliveira
Ian Schneider
Justin Deoliveira
Justin,
As you've suggested, I implemented the headers check to preserve
backwards compatibility. This implies that Response implementations
that provide Content-Disposition will not support the new client API
that allows requesting an alternate disposition. I extracted the code
to add headers to a separate method. As an added benefit, each OWS
request that used the old header API now produces 2 less 2D String
arrays per request
I've added this new Dispatcher patch to the JIRA ticket. Please review
and let me know how this looks.
Finally, I apologize for the grief I caused Gabriel for making GWC break.
-Ian
On Wed, Jul 27, 2011 at 5:02 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey Ian,
wrote:
Hey Justin,
Just that a "mostly backward compatible" approach will suffice when a
advocating for that so "don't agree" was poor phrasing on my part.
so "out of tree" implementations should be considered. During my time people
trying to implement custom output formats have come up a number of times...
I imagine many of them don't get contributed back, often with good reason
use the new API).
-Ian
> lightly.
> about
> wrote:
>> Hey Justin,
>> wrote:
>> > Hi Ian,
>> > existing
>> > enough)
>> > wrote:
>> >> Hi everyone,
>> >> was
>> >> (attachment
>> >> with
>> >> preference.
>> >> implementations.
>> >> -Ian
>> >> Ian Schneider
>> > Justin Deoliveira
>> Ian Schneider
> Justin Deoliveira
Ian Schneider
Justin Deoliveira
Ian Schneider
