[Geoserver-devel] GEOS-6711
Hi.
Any objections to backporting authkey module improvements to 2.6.x, 2.5.x and 2.4.x?
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Not from here. I am wondering about 2.4.x, is there still an active development ?
Christian
On Wed, Nov 5, 2014 at 9:31 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com.1268…> wrote:
Hi.
Mauro
@mauro_bart
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
2014-11-05 9:39 GMT+01:00 Christian Mueller <christian.mueller@anonymised.com>:
I don’t think so, but since we have some customers using a 2.4.x version it would be good to have a nightly including the improvements. To tell you the truth, I am not sure if 2.4.x nightlies are still generated. If not, I will skip the 2.4.x backport.
Mauro
@mauro_bart
Ciao Mauro,
2.4.x nightlies are not generate any longer.
Anyhow, I would backport to 2.4.x if that does not require too much time.
Simone.
Mauro
@mauro_bart
We still make bug fix releases, but are not back porting any new features.
For reference we are getting some downloads of the maintenance branch, but nothing compared to the latest. I expect 2.4.x to remain popular as organizations wrestle with the requirement to upgrade to Java 7.
On Wed, Nov 5, 2014 at 12:39 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Christian
Jody Garnett
On Wed, Nov 5, 2014 at 9:31 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi.
Mauro
@mauro_bart
On Wed, Nov 5, 2014 at 11:48 PM, Jody Garnett <jody.garnett@anonymised.com>
You as in... Boundless?
The GeoServer project does not have any more 2.4.x releases planned,
though, if we found the resources, it might not be a bad thing
to keep on doing them
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
That should be GeoServer 2.5.x (i.e. our last java 6 release).
Jody Garnett
On November 6, 2014 at 11:20:37 PM, Andrea Aime (andrea.aime@anonymised.com) wrote:
