[Geoserver-devel] GEOS-7349: GeoJSON geometry and geometry_name inconsistent on multi-geometry features
Hi GeoServer-Developers,
Andrea Aime asked me to involve this mailing list regarding the
following issue & pull request:
https://osgeo-org.atlassian.net/browse/GEOS-7349
https://github.com/geoserver/geoserver/pull/1370
Context:
- GeoServer WFS-Response with outputFormat=JSON
- FeatureType with multiple geometries
- any of the geometries might be null
- the JSON contains one "geometry" attribute, which might be null,
according to the spec
- the JSON contains one "geometry_name" attribute, which defines the
name of the attribute providing the value for the above
- GeoTools FeatureTypes have a "default geometry"
Question:
- What is the desired behaviour if the default geometry of the feature is null?
Solutions:
1) write "null" to the JSON "geometry" field and write the name of the
default geometry attribute to "geometry_name"
Pro: The value of the "geometry_name" field will be the name of the
GeoTools default geometry attribute, consistently across all features
of a feature type.
2) Serialize the first not-null geometry of the feature to the JSON
"geometry" field and write the corresponding field name to
"geometry_name"
Pro: The JSON default geometry will be populated more often than in
1). This makes it more likely for the feature to be displayed
out-of-the-box, like in OpenLayers.
Currently, in this case the "geometry_name" does not correspond to the
value of "geometry".
I can offer to fix this issue. Please given me a feedback which way you prefer.
Best regards,
Andreas
Andreas
ITS Telco Services GmbH
GIS Services & Solutions
Telecommunications Division
Dillenburger Str. 77
D-51105 Köln
Tel.: +49 (0)221 820 07 00
Fax : +49 (0)221 820 07 22
Mail: info@anonymised.com
Web : http://www.its-telco.de
Sitz der Gesellschaft: Köln
Amtsgericht Köln, HRB 59310
Geschäftsführer: Gunnar Haack, Ralf Petersilka, Michael Schnepf, Kai
Schriewer, Ludger Schulte
Diese E-Mail enthält vertrauliche Informationen. Wenn Sie nicht der
richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
informieren Sie bitte sofort den Absender und vernichten Sie diese
E-Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser
E-Mail ist nicht gestattet.
This e-mail may contain confidential information. If you are not the
intended recipient (or have received this e-mail in error) please
notify the sender immediately and destroy this e-mail. Any
unauthorised copying, disclosure or distribution of the material in
this e-mail is strictly forbidden.
I was hoping for others to chime in, but… well, let me break the ice.
Personally I like option 1) better, it makes GeoJSON consistent with the other
formats.
Note for others, the current behavior is a mix of 1 and 2 that is just wrong, it declares
the geometry attribute as the default geometry, but then the value is the
first non null geometry found. Just broken imho.
On Mon, Dec 21, 2015 at 1:06 PM, Andreas Watermeyer <Andreas.Watermeyer@anonymised.com> wrote:
Context:
  • GeoServer WFS-Response with outputFormat=JSON
  • FeatureType with multiple geometries
  • any of the geometries might be null
  • the JSON contains one “geometry” attribute, which might be null,
  • the JSON contains one “geometry_name” attribute, which defines the
  • GeoTools FeatureTypes have a “default geometry”
Question:
  • What is the desired behaviour if the default geometry of the feature is null?
Solutions:
  1. write “null” to the JSON “geometry” field and write the name of the
    default geometry attribute to “geometry_name”
    Pro: The value of the “geometry_name” field will be the name of the
    of a feature type.
  2. Serialize the first not-null geometry of the feature to the JSON
    “geometry” field and write the corresponding field name to
    “geometry_name”
Currently, in this case the “geometry_name” does not correspond to the
value of “geometry”.
Best regards,
Andreas
Andreas
D-51105 Köln
Geoserver-devel mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I suppose solution 1) is accepted by all.
I will create a pull request.
Best regards,
Andreas
