[Geoserver-devel] [GEOS-7852] - GoeServer CatalogFacade API violation
I found an interesting behavior in the GeoServer REST API today. Details described here: here https://osgeo-org.atlassian.net/browse/GEOS-7852
While it does not impact functionality of core GeoServer, it could be construed as a violation of the CatalodFacade interface / api.
Unless there was a good reason for this implementation, I think it should be fixed.
PR here: https://github.com/geoserver/geoserver/pull/1966
Opinions welcome.
Hi Torben,
wondering, wouldn’t it be better to add that same code to the CatalogImpl instead?
In order to make the same issue impossible from other (future and unaware) calling points?
On Tue, Nov 15, 2016 at 1:45 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Opinions welcome.
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I agree that would be a good idea, although that would technically be a reduction in functionality… perhaps some sort of warning in the logs for 1 version, then removal later?
Torben
On Tue, Nov 15, 2016 at 6:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
Opinions welcome.
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Nov 15, 2016 at 4:41 PM, Torben Barsballe <
reduction in functionality... perhaps some sort of warning in the logs for
I lost you, why would it be a regression? Being able to set a workspace
that is not even in the catalog
as the default seems to be a bug... but wait... I see this in CatalogImpl:
    public void setDefaultWorkspace(WorkspaceInfo workspace) {
        if (workspace != null &&
facade.getWorkspaceByName(workspace.getName()) == null) {
            facade.add(workspace);
        facade.setDefaultWorkspace(workspace);
So what about changing it roughly this way:
        if (workspace == null) {
        WorkspaceInfo ws = facade.getWorkspaceByName(workspace.getName());
        if(ws == null) {
            facade.add(ws);
        facade.setDefaultWorkspace(ws);
Wouldn't this solve your problem and prevent similar potential issues in
other places?
Ing. Andrea Aime
@geowolf
Technical Lead
I see what you mean. Sorry, I was mixing up CatalogImpl and CatalogFacade in my head there (I was thinking you meant to remove the current workaround from the facade).
Yes, that change does make sense.
Torben
On Tue, Nov 15, 2016 at 10:23 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Nov 15, 2016 at 4:41 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
I lost you, why would it be a regression? Being able to set a workspace that is not even in the catalog
as the default seems to be a bug… but wait… I see this in CatalogImpl:
if (workspace != null && facade.getWorkspaceByName(workspace.getName()) == null) {
if(ws == null) {
facade.add(ws);
Wouldn’t this solve your problem and prevent similar potential issues in other places?
Ing. Andrea Aime
@geowolf
Technical Lead
Looking at the CatalogImpl implementation of setDefaultNamespace(), we already do something like this there:
public void setDefaultNamespace(NamespaceInfo defaultNamespace) {
if(defaultNamespace != null) {
NamespaceInfo ns = getNamespaceByPrefix( defaultNamespace.getPrefix() );
if ( ns == null ) {
throw new IllegalArgumentException( “No such namespace: '” + defaultNamespace.getPrefix() + “'” );
facade.setDefaultNamespace(defaultNamespace);
However, rather than adding the namespace, we throw an exception. Do we want to do the same for workspace (throw an exception if it is not in the Catalog)?
Personally, I think throwing an exception makes a bit more sense than adding it to the catalog (Especially from the REST API perspective - consider trying to set the default workspace to some existing workspace but making a typo in the name - having a new workspace added to the catalog is not what I would expect in that situation)
Torben
On Tue, Nov 15, 2016 at 10:27 AM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
On Tue, Nov 15, 2016 at 10:23 AM, Andrea Aime <andrea.aime@anonymised.com1268…> wrote:
if(ws == null) {
facade.add(ws);
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Nov 15, 2016 at 7:59 PM, Torben Barsballe <
            if ( ns == null ) {
                throw new IllegalArgumentException( "No such namespace: '"
+ defaultNamespace.getPrefix() + "'" );
Catalog)?
I like throwing the exception more myself too
Ing. Andrea Aime
@geowolf
Technical Lead
