[Geoserver-devel] [GEOS-8079] Default raster style cannot be used generically
Greetings all,
Working in a development environment today, discovered a bug relating to raster layer rendering. It seems the default raster layer sld defined in GeoServer’s catalog causes raster layers which use this style to break such that GeoServer cannot render them. This is undesireable behaviour for us because by default, we use this default template unless the user specifies something else, and besides the default style template I expect to work correctly.
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/resources/org/geoserver/catalog/template_raster.sld#L9
The reason it breaks seems to be the <FeatureTypeName> tag given “Raster”, since this doesn’t mean anything out of context. The tag can still be used in a style appropriately, it’s just this default set to “Raster” will cause the raster layers using it to be unable to render in GeoServer.
I made a bug report, [GEOS-8079] concerning this problem and did a quick PR to remove the line:
https://github.com/geoserver/geoserver/pull/2215
My understanding is that it should be fine to just remove this line, since it is a default template and there is no need for this tag to have a functioning sld. It makes the default template simpler and more generic. You can always define your own sld with a <FeatureTypeName> if desired anyway.
Travis
Travis Brundage
Software Engineer | Boundless
tbrundage@anonymised.com…3839…
250.888.2820
@boundlessgeo
On Sat, Apr 8, 2017 at 2:59 AM, Travis Brundage <tbrundage@anonymised.com>
wrote:
Greetings all,
GeoServer's catalog causes raster layers which use this style to break such
"Break" can mean anything. Break how? Blank display? Exception?
As far as I can tell, it's a blank display case.
<https://osgeo-org.atlassian.net/browse/GEOS-8079&gt; concerning this
You can always define your own sld with a `<FeatureTypeName>` if desired
anyway.
Checked, yes, seems like a good fix.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
