I'd like to add a community module to trunk to work on the features discussed
here: http://geoserver.org/display/GEOS/Exposing+to+Geo+Search
-David
-David
A couple bits of specific feedback:
Note that filters are CQL filters, not the normal ogc xml filters.
Can you consider the "expanded" TXT format that supports featureId
- http://jira.codehaus.org/browse/GEOT-1666
Ends up support: #road.1,#road.2, #road.47 for a featureId filter
For your stable identifiers of features you list:
http://geoserver.org/geoserver/features/roads/1
http://geoserver.org/geoserver/features/roads/1.kml <http://geoserver.org/geoserver/features/roads/1>
The convention of "road.1" for feature id matching shapefile row 1 is only a convention; the only thing we *know* is that the feature id must start with a letter. Would the following work?
http://geoserver.org/geoserver/features/roads.1 <http://geoserver.org/geoserver/features/roads/1>
http://geoserver.org/geoserver/features/roads.1 <http://geoserver.org/geoserver/features/roads/1>\.kml
Jody
I'd like to add a community module to trunk to work on the features discussed here: http://geoserver.org/display/GEOS/Exposing+to+Geo+Search
-David
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-devel mailing list
+1 from me.
David Winslow wrote:
-David
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:4007,47f28907270011096210785!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
