A new release is available. This is "sanity check" release so we didn't go through the process of releasing on sourceforge, however there are a few notable features listed below. You can download the new release from:
The major changes since RC3 have been:
* Color Scheme
* Indexed Shapefile support
* Data Store Editor User Interface improvements
* Compression/Decompression of remote SLD documents
* Improved support for XML request character set detection
* PostGIS data store - more intuitive error messages regarding permissions
A new release is available. This is “sanity check” release so we didn’t go through the process of releasing on sourceforge, however there are a few notable features listed below. You can download the new release from:
A couple marks of insanity (can we have the following links use both html or both htm ? )
GeoServer Administration - links is broken when new user first installs, it is the first thing they will try
GeoServer Documentation - link is broken (in a special way - see attached)
This is what will be checked when the first link does not work
okay starting geoserver …
may consider telling them the user that geoserver is loaded and which url they can visit to connect to it.
noticed a few complaints in the start geoserver output about postgis …
After starting geoserver the “GeoServer Administration” link functions
Based on new color scheme, nice, I need to make a new pdf walkthrough…
So time to uninstall …
uninstaller works, expect if you fail to stop geoserver …
After that Stop GeoServer no longer actually stops it …
Time to kill geoserver the old fashioned way … and uninstall.
Death … removing everything by hand (when I screw up I do so well)
Stay tuned for the udig tests … uDig 1.0.5 must go out!
Jody
A new release is available. This is "sanity check" release so we didn't go through the process of releasing on sourceforge, however there are a few notable features listed below. You can download the new release from: http://dist.codehaus.org/geoserver/
Stay tuned for the udig tests ... uDig 1.0.5 must go out!
