I just installed the beta 4 which went very smoothly.
When I moved over the catalog.xml and feature_types from my beta 3 environment, it was very unhappy. Replacing the gt2-main.jar with the one from beta 3 made it happy again.
This is the error on stderr:
java.lang.NoClassDefFoundError: javax/media/jai/WarpAffine
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at sun.misc.Service$LazyIterator.next(Unknown Source)
at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:420)
at org.geotools.factory.FactoryRegistry.getServiceProviders(FactoryRegistry.java:114)
at org.geotools.referencing.operation.MathTransformFactory.getProvider(MathTransformFactory.java:255)
at org.geotools.referencing.operation.MathTransformFactory.getDefaultParameters(MathTransformFactory.java:289)
at org.geotools.referencing.wkt.Parser.parseProjection(Parser.java:565)
at org.geotools.referencing.wkt.Parser.parseProjCS(Parser.java:864)
at org.geotools.referencing.wkt.Parser.parseCoordinateReferenceSystem(Parser.java:263)
at org.geotools.referencing.wkt.Parser.parseCoordinateReferenceSystem(Parser.java:244)
at org.geotools.referencing.factory.GeotoolsFactory.createFromWKT(GeotoolsFactory.java:1080)
at org.geotools.data.db2.DB2CoordinateSystem.getCRS(DB2CoordinateSystem.java:123)
at org.geotools.data.db2.DB2GeometryColumn.getCRS(DB2GeometryColumn.java:89)
at org.geotools.data.db2.DB2SpatialCatalog.getCRS(DB2SpatialCatalog.java:414)
at org.geotools.data.db2.DB2DataStore.buildAttributeType(DB2DataStore.java:165)
at org.geotools.data.jdbc.JDBCDataStore.buildSchema(JDBCDataStore.java:1232)
at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java:200)
at org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java:168)
at org.geotools.data.jdbc.JDBCDataStore.getSchema(JDBCDataStore.java:499)
at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:345)
at org.vfny.geoserver.global.Data.load(Data.java:154)
at org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:109)
The following lines from stdout may be related:
3204 [FINE] org.geotools.referencing.factory.DatumAliases - Loading datum aliases from “jar:file:/E:/geotools/geoserver13b4/server/geoserver/WEB-INF/lib/gt2-main.jar!/org/geotools/referencing/factory/DatumAliasesTable.txt”.
3297 [FINE] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Connection closed - adding to available connections.
3297 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo cgf:::MLines ignored - as DataStore cgf is broken:java.lang.NoClassDefFoundError: javax/media/jai/WarpAffine
Any ideas?
