1. made a note of this in the install guide. Thanks for tracking down
the issue.
2. The WFS isnt actually doing any reprojection, but if you've specified
a SRS in the info.xml (ie. on the FeatureType editor page) then it will
probably try to instantiate it. Also, if your datastore (ie.
DB2/PostGIS/Shapefile) is reporting a projection, then the datastore
will attempt to create a CoordinateReferenceSystem for it.
Geoserver WFS doesnt do any reprojection at all.
dave
This mail sent through IMP: https://webmail.limegroup.com/
