[Geoserver-devel] geoserver-1.4.x_merge_wcs from svn depends on geotools-2.3.0-RC1-SNAPSHOT which is not (yet) available
Hi devs,
geoserver-1.4.x_merge_wcs from svn depends on geotools-2.3.0-RC1-SNAPSHOT which is not (yet) available from the geotools m2 repo. See the following error on mvn compile:
vincent@anonymised.com /usr/local/src/geoserver-1.4.x_merge_wcs $ mvn compile
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] Web Application Module
[INFO] Artifact Merger PlugIn
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer
[INFO] task-segment: [compile]
[INFO] Building Core Platform Module
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading: http://lists.refractions.net/m2//org/geotools/gt2-main/2.3.0-RC1-SNAPSHOT/gt2-main-2.3.0-RC1-SNAPSHOT.pom
[WARNING] Unable to get resource from repository refractions (http://lists.refractions.net/m2/)
Downloading: http://lists.refractions.net/m2//org/geotools/gt2-api/2.3.0-RC1-SNAPSHOT/gt2-api-2.3.0-RC1-SNAPSHOT.pom
Downloading: http://lists.refractions.net/m2//org/geotools/gt2-api/2.3.0-RC1-SNAPSHOT/gt2-api-2.3.0-RC1-SNAPSHOT.jar
Downloading: http://lists.refractions.net/m2//org/geotools/gt2-main/2.3.0-RC1-SNAPSHOT/gt2-main-2.3.0-RC1-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt2-api:jar:2.3.0-RC1-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt2-api \
          -Dversion=2.3.0-RC1-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Path to dependency:
        1) org.geoserver:platform:jar:1.4.0-M2-WCS
        2) org.geotools:gt2-api:jar:2.3.0-RC1-SNAPSHOT
2) org.geotools:gt2-main:jar:2.3.0-RC1-SNAPSHOT
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt2-main \
  Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
  espace (http://maven.espace.ird.nc),
  geotools (http://maven.geotools.fr/repository/),
  mortbay (http://www.mortbay.org/maven2/release),
  refractions (http://lists.refractions.net/m2/),
  central (http://repo1.maven.org/maven2),
  ibiblio (http://www.ibiblio.org/maven2)
[INFO] Total time: 4 seconds
[INFO] Finished at: Thu Oct 12 13:54:51 CEST 2006
[INFO] Final Memory: 9M/21M
I checked the geotools repo manually and these jars are indeed missing.
Vincent.
Ciao Vincent,
the raster-branch of geoserver depends on the 2.3.x branch of geotools.
If you download and build the source code of the geoserver branch you
need also to download and build the code for the correlated geotools
2.3.x branch which can be found here
http://svn.geotools.org/geotools/branches/2.3.x
in order to build the jars needed for geoserver
Anyway, within next week we should create a new release of the
geoserver raster branch together with the geotools 2.3.-rc1 release.
Simone.
On 10/12/06, Vincent Schut <schut@anonymised.com> wrote:
Hi devs,
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
[INFO]
[INFO]
Downloading:
Downloading:
Downloading:
Downloading:
[INFO]
[ERROR] BUILD ERROR
[INFO]
Missing:
Path to dependency:
Path to dependency:
for artifact:
[INFO]
[INFO]
[INFO]
Vincent.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions
