[Geoserver-devel] Geoserver 1.4.x not working in tomcat 5.5... where is wkb4j-modified?
we're still unable to deploy in tomcat 5.5 due to the broken attribute in the wkb4j
manifest file.... now, I think we need to act on this... I'm ready to setup a wkb4j
module in geoserver and copying over the source code and fix the damn jar
if that would solve the problem once for all...
WKB4J is LGPL se we would not be doing anything wrong....
Suggestions?
When I removed the dependency it was only from postgis on trunk. I can
do it on 2.3.x as well. I will also upload the modified jar to the
refractions maven repository.
-Justin
aaime wrote:
in the wkb4j
setup a wkb4j
Suggestions?
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,45422d50152681425493344!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Yeah, please do. I thought we had fixed this already...
-Justin
aaime wrote:
Suggestions?
Chris Holmes
http://topp.openplans.org
Well, on 1.4.x we updated the wkb4j dependencies (in fact, in gt2 2.2.x) and tried again, works now.
For trunk it should be a different story, since they are depending on 2.3.x which uses jts 1.7,
so I guess they do not need wkb4j at all (just not sure if Justin removed the wkb dependency
before or after the branch...)
