[Geoserver-devel] GeoServer 1.4.x + WMS with Rasters
Commited here https://svn.codehaus.org/geoserver/branches/1.4.x_debugged_trunk_wcs the last release of GeoServer 1.4.x with more debugging (I think that this release is stable like the old 1.3.2) + wcs module (optional) and wms raster enabled.
KML and KMZ needs some debug in order to work correctly with rasters too … it will be done very soon.
Few notices:
  • wcs and rasters work only with GeoTools 2.3.x (the merge with trunk is in progress, but the plugins are still a bit unstable); however temporally if you would like to compile all modules, you can download GeoTools 2.3.x source code compatible with 2.2.x here http://svn.geotools.org/geotools/branches/coverages_branch/branches/2.2.x-compatible-GeoServer_1.4.x/
    (it will be deleted after the merge is done)
  • wkb4j.jar doesn’t allow geoserver.war to be deployed on Tomcat because of a wrong METAINFO.MF descriptor inside the jar.
Alessio.
Alessio Fabiani
Software Engineer
http://afabiani.wordpress.com
