[Geoserver-devel] GeoServer 1.4.x
Speaking about the new release of GeoServer and the use of Spring, we should start thinking on a new configuration system of GeoServer. At least two aspects should be considered:
1 - The GeoServer active context should be persisted somewhere and GeoServer should have the possibility to read Stores, Features and Coverages metadata from the storage instead of having all things in memory. A reading cache algorithm could be implemented too obviously. For instance Spring could be a good solution using JDO to persist Beans.
2 - The actual Data Configuration system is too hard to use. In the WCS experiment in order to be less invasive as possible I added the possibility to create CoverageStores and FeaturesStores and then create Coverages and FeatureTypes from them… In a future relase I would like to see a unique DataStore and a unique way to obtain Data from the latter giving to the user the feeling that the catalog is unique for all kind of Data. This issue has to be considered in an optic of having separate modules. What I would like to avoid is to have a different configration for each new module I add.
Alessio.
Alessio Fabiani
Software Engineer
http://afabiani.wordpress.com
Hi Allessio,
Yes, the configuration system needs to be redone imho. For the first release of 1.4.x we are leaving it as is as its kind out of scope. Once we get things refactored into a cleaner module system, we can actually start talking about cleaning up configuration as an attainable goal.
I dont want to step on the toes or discourage the people who wrote the current system. Because it works, and works darn good.
Further comments in line.
I would like to see an embedded database used (perhaps hsql). I am not that familiar with the JDO spec but I am all for going with a standard for persistence. Here is an article linking the two up. I gave it a quick once over, not sure if it is any good.
http://www.informit.com/articles/article.asp?p=212397&rl=1
Spring also seems to have a lot of good support for JDO just like Hibernate. Hibernate of course could be another option.
However as a developer writing a geoserver plugin, I want to be hidden from all this and have my POJO's persisted by GeoServer, how its being done should really be hidden from me. Of course unless I want to get into things like Transactions and such, no promises there :).
FeatureTypes from them... In a future relase I would like to see a unique
Agreed. I need to look at what you are guys are up to on wcs-branch. I plan to checkout the branch so I can at least talk intelligently about what is going on. I would like to face the issue of merging you guys back in sooner rather then later. And with all the 1.4.x re modularizing going now might just be the best time to do it.
I know that you guys are working off of geotools trunk correct? A worth while experiment would see how much work it is to get 1.4.x onto trunk as its on 2.2.x right now. I think dave may have looked into this. My impression from what has been going is not a lot. I think the biggest change is the Expression api changeover, and that was done to keep thing totally backwards compatible.
        Alessio.
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira ha scritto:
Hi Allessio,
May I suggest h2database (www.h2database.com)? Seems to be a lot faster :slight_smile:
> I am not
JDO as a standard has been largely supplanted by EJB3 persistence, which,
surprise, is largely influenced by Hibernate (and Hibernate does implement
the EJB3 standard). Ok, I've been using Hibernate since version 0.8, so
I'm really really biased :slight_smile:
Easy, just provide some DAO or service objects that shield the user
from the actual technology used to persist data.
No worries we wrote it under strict restrictions :slight_smile:
Um I have three letters for you:
JMX
And some links
- Dr. Dobb's | Good stuff for serious developers: Programming Tools, Code, C++, Java, HTML5, Cloud, Mobile, Testing
- Java Management Extensions (JMX)
Seriously this is a wheel I want to steal rather then reinvent :slight_smile:
Jody
JMX
And some links
Correction:
- http://www.ddj.com/showArticle.jhtml?articleID=185300352
And a link to a tutorial:
- JMX Connectors
It does look like MBeans allows for dynamic content, something that messed up our evaulation of this technology the
first time around - and thus had us build a struts web app :slight_smile:
Jody
