I encountered a blocker bug with WFS Inserts into a backend ArcSDE table
where the row id column is USER managed.
I tracked the error leading to
in geotools-2.5-M3
in ArcSdeFeatureWriter.java
in method insertSeRow(final SimpleFeature, final SeLayer)
if ((fidReader instanceof FIDReader.SdeManagedFidReader)) {
SeObjectId newRowId = insertStream.lastInsertedRowId();
newId = Long.valueOf(newRowId.longValue());
} else {
throw new DataSourceException("fid reader is not user nor sde managed");
It appears that the current code will only allow for inserts into ArcSDE
tables where the row id is SDE managed?
View this message in context: http://www.nabble.com/geoserver-1.7.0-RC1-WFS-T-transactions-ArcSDE-User-Manager-Row-Id-tp19175979p19175979.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Qunncyme,
indeed it looks like a brutal bug.
I'm adding a test case right now, thanks for the catch
Gabriel
in geotools-2.5-M3
} else {
ah, sorry, forgot to mention one thing.
Actually there is not a problem with that code, because non user nor sde
managed rowid tables are treated as read only.
Have you get to that piece of code because of an actual failure or just by
looking at it. It may worth a comment on the code, but as far as I can tell,
it is handling the case for user and sde managed row ids, and for a table
with no pk you would never get that far because DataStore.getFeaureSource
will return a FeatureSource and not a FeatureStore.
Do you have a way to reproduce an actual error though?
Gabriel
On Wednesday 03 September 2008 06:13:41 pm Gabriel Roldán wrote:
Hi Qunncyme,
Gabriel
> in geotools-2.5-M3
> } else {
> managed"); }
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK & win
great prizes Grand prize is a trip for two to an Open Source event anywhere
in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-devel mailing list
Perhaps, I' miss understood what the code was trying to do, anyhow I'll
continue doing more testing and report any errors encountered.
But to be on the safe side I think its best that arcsde users stick to using
sde managed row ids for now.
thanks.
Quincyme
tell,
Gabriel
Hi Qunncyme,
Gabriel
table
> in geotools-2.5-M3
> } else {
> managed"); }
ArcSDE
win
anywhere
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
View this message in context: http://www.nabble.com/geoserver-1.7.0-RC1-WFS-T-transactions-ArcSDE-User-Manager-Row-Id-tp19175979p19304822.html
yeah please do, you can't imagine how much appreciated is that.
using sde managed row ids for now.
sure thing, or, as said, you'll end up with read-only feature types.
regards,
Gabriel
thanks.
Quincyme
> by looking at it. It may worth a comment on the code, but as far as I can
> tell,
> Cheers,
> Gabriel
>> Hi Qunncyme,
>> Gabriel
>> table
>> > in geotools-2.5-M3
>> > } else {
>> > managed"); }
>> ArcSDE
>>- This SF.Net email is sponsored by the Moblin Your Move Developer's
>> win
>> anywhere
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> challenge
> prizes
> world
