Hi All,
I'm trying (did it already) to mount a geoserver 1.7.2 project at eclipse.
In the web module, i ran test class and the jetty is running successfully.
The issue is, i use Oracle database, so, in this geoserver (running from
eclipse), the datastore doesn't have "Oracle" option. In a normal situation,
i have to copy ojdbc and gt-oralce-plugin jar files into lib folder. There
is any way i could have the oracle datastore in the geoserver running at
jetty.
As i want to have the oracle source in my project, how can i add some
geotools modules to my geoserver project? If it is possible to run in real
time at jetty?
At last, i would like to know which modules do i need to add (from geotools)
to my geoserver project so i could change the oracle plugin.
Many thanks.
D.Nunes
View this message in context: http://www.nabble.com/Geoserver-1.7.2-Geotools-2.5.3-Eclipse-Project-tp21788388p21788388.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
