The GeoServer team is pleased to announce GeoServer 1.7.7, the latest in the current series of stable releases. Download this release from:
http://geoserver.org/display/GEOS/GeoServer+1.7.7
This release sees a number of fixes and improvements, including:
* Enhancements to the REST API
* Memory leaks in GetMap requests plugged
* Removing rare GetFeature connection leaks
* Improved consistency in the generation of shapefile output
* Many and varied documentation improvements
The entire change log is available at:
http://jira.codehaus.org/browse/GEOS/fixforversion/15542
Mark Leslie
Geospatial Software Architect
LISAsoft
It's not possible to build this GeoServer release from sources:
org.geotools:gt-validation:jar:2.5.8
is missing, this version is not available under
http://download.osgeo.org/webdav/geotools/org/geotools/gt-validation/
Could it be that someone missed to upload this artifact? A quick look into
other gt-* directories indicated that geotools 2.5.8 is available.
Yours,
Björn
View this message in context: http://www.nabble.com/GeoServer-1.7.7-Released-tp25885180p25887182.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hello developers,
I'm still trying to build GeoServer 1.7.7 from (SourceForge-published) sources, but without success.
gt-validation is now available, but another artifact is missing:
org.geotools:gt-directory:jar:2.5.8
Am I doing something wrong? Shouldn't just a "mvn clean install" do the job? Did you build the
released binaries in a different way?
Björn
PS: 2.0.0-RC2 builds and runs successfully
-----Original Message-----
