Luis F. Amorim França ha scritto:
I tried again "mvn install" at branch 1.7.x and got the following message:
[ERROR] BUILD ERROR
[INFO] Failed to execute: Executing Ant script: /config.build.xml [config]: Failed to execute.
Unable to locate configuration: /home/user/workspace/geoserver/src/web/minimal
[INFO] Total time: 13 minutes 47 seconds
[INFO] Finished at: Sat Jul 25 14:37:30 BRT 2009
[INFO] Final Memory: 156M/236M
At least now I get the /web/minimal instead of "app"; but still doesn`t work.
Hmmm... so yo don't have the minimal directory in the web folder?
It's a svn external, should be checked out by svn automatically.
To double check I just did a:
svn co http://svn.codehaus.org/geoserver/branches/1.7.x geoserver
and got this output:
A geoserver/doc
A geoserver/doc/en
A geoserver/doc/en/theme
A geoserver/doc/en/theme/_static
A geoserver/doc/en/theme/_static/doctools.js
A geoserver/doc/en/theme/_static/searchtools.js
A geoserver/doc/en/theme/_static/blueprint
A geoserver/doc/en/theme/_static/blueprint/LICENSE
A geoserver/doc/en/theme/_static/blueprint/print.css
A geoserver/doc/en/theme/_static/blueprint/ie.css
A geoserver/doc/en/theme/_static/blueprint/AUTHORS
A geoserver/doc/en/theme/_static/blueprint/screen.css
A geoserver/doc/en/theme/_static/GeoServer_500.png
A geoserver/doc/en/theme/_static/jquery.js
A geoserver/doc/en/theme/_static/default.css
A geoserver/doc/en/theme/_static/chrome
A geoserver/doc/en/theme/_static/chrome/search_icon_green.png
A geoserver/doc/en/theme/_static/chrome/header-bg.png
Caricamento di oggetto esterno in 'geoserver/data/citewfs-1.1-h2/featureTypes/sf_PrimitiveGeoFeature'
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_PrimitiveGeoFeature/info.xml
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_PrimitiveGeoFeature/schema.xsd
L'oggetto esterno è stato estratto alla revisione 12971.
Caricamento di oggetto esterno in 'geoserver/data/citewfs-1.1-h2/featureTypes/sf_AggregateGeoFeature'
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_AggregateGeoFeature/info.xml
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_AggregateGeoFeature/schema.xsd
Caricamento di oggetto esterno in 'geoserver/data/citewfs-1.1-h2/featureTypes/sf_EntitéGénérique'
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_EntitéGénérique/info.xml
A geoserver/data/citewfs-1.1-h2/featureTypes/sf_EntitéGénérique/schema.xsd
Caricamento di oggetto esterno in 'geoserver/data/citewfs-1.1-h2/styles'
A geoserver/data/citewfs-1.1-h2/styles/normal.sld
Caricamento di oggetto esterno in 'geoserver/src/web/minimal'
A geoserver/src/web/minimal/featureTypes
A geoserver/src/web/minimal/plugIns
A geoserver/src/web/minimal/services.xml
A geoserver/src/web/minimal/styles
A geoserver/src/web/minimal/styles/raster.sld
A geoserver/src/web/minimal/styles/default_line.sld
A geoserver/src/web/minimal/styles/default_polygon.sld
A geoserver/src/web/minimal/styles/default_point.sld
A geoserver/src/web/minimal/demo
A geoserver/src/web/minimal/images
A geoserver/src/web/minimal/images/deleteRed.png
A geoserver/src/web/minimal/images/gs.ico
A geoserver/src/web/minimal/images/rasterLegend.png
A geoserver/src/web/minimal/images/delete.png
A geoserver/src/web/minimal/images/up.png
A geoserver/src/web/minimal/images/down.png
A geoserver/src/web/minimal/images/colorpicker.jpg
A geoserver/src/web/minimal/images/gs.gif
A geoserver/src/web/minimal/mbdemos
A geoserver/src/web/minimal/capabilities
A geoserver/src/web/minimal/catalog.xml
A geoserver/src/web/minimal/data
A geoserver/src/web/minimal/validation
A geoserver/src/web/minimal/coverages
A geoserver/src/web/minimal/templates
Caricamento di oggetto esterno in 'geoserver/data/citewfs-1.1-h2-xlink/featureTypes/sf_PrimitiveGeoFeature'
A geoserver/data/citewfs-1.1-h2-xlink/featureTypes/sf_PrimitiveGeoFeature/info.xml
A geoserver/data/citewfs-1.1-h2-xlink/featureTypes/sf_PrimitiveGeoFeature/schema.xsd
Caricamento di oggetto esterno in 'geoserver/doc/en/developer/source/subversion'
A geoserver/doc/en/developer/source/subversion/config
L'oggetto esterno è stato estratto alla revisione 33627.
Estratta revisione 12971.
And then:
cd geoserver/src
mvn install
aaime@anonymised.com:/tmp/geoserver/src$ mvn install
[INFO] Scanning for projects...
[WARNING] Overriding profile: 'geosearch' (source: pom) with new instance from source: pom
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Configuration Deployment PlugIn
[INFO] GeoServer Maven Archetypes
[INFO] GeoServer WFS Output Format Archetype
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.1.1 Module
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Geoserver REST Support Code
[INFO] GeoWebCache (GWC) Module
[INFO] Web Application Module
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [33.684s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.278s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.124s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.059s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.254s]
[INFO] Core Platform Module .................................. SUCCESS [3.645s]
[INFO] Data Module ........................................... SUCCESS [57.848s]
[INFO] Open Web Service Module ............................... SUCCESS [13.230s]
[INFO] Main Module ........................................... SUCCESS [23.642s]
[INFO] Web Coverage Service Module ........................... SUCCESS [23.833s]
[INFO] Web Coverage Service 1.1.1 Module ..................... SUCCESS [36.825s]
[INFO] Validation Module ..................................... SUCCESS [0.961s]
[INFO] Web Feature Service Module ............................ SUCCESS [34.207s]
[INFO] Web Feature Service Module ............................ SUCCESS [26.053s]
[INFO] Web Map Service Module ................................ SUCCESS [1:05.780s]
[INFO] Geoserver REST Support Code ........................... SUCCESS [9.292s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.708s]
[INFO] Web Application Module ................................ SUCCESS [25.329s]
[INFO] Community Space ....................................... SUCCESS [0.066s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.100s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 6 minutes 2 seconds
[INFO] Finished at: Sat Jul 25 20:09:36 CEST 2009
[INFO] Final Memory: 65M/183M
I guess there is something different on your system, but I don't know what. I'm on Ubuntu 9.04, svn 1.5.4, java 1.5.0_18, maven 2.1.0
Andrea Aime
OpenGeo - http://opengeo.org
