[Geoserver-devel] Geoserver 2.0.2 release
I am closing to finishing the deployment but my mvn deploy (done from src
folder) return error saying system is offline.
I have issues with creating the documentation as well, creating the pdf and
not to sure where to generate the html to get the desired file structure.
My pdflatex(MikeTex) is not happy generating the pdf probably because of the
Apology for not being able to get this out today and will tidy this up
tomorrow.
View this message in context: http://old.nabble.com/Geoserver-2.0.2-release-tp28619049p28619049.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
I am trying to get access to deploy the artifacts for the Geoserver2.0.2
release. Can anyone help out?
and not to sure where to generate the html to get the desired file
structure. My pdflatex(MikeTex) is not happy generating the pdf probably
tomorrow.
View this message in context: http://old.nabble.com/Geoserver-2.0.2-release-tp28619049p28629318.html
I've found that in the interests of expediency, it is possible to create the PDF by powering through the errors (just hitting Enter a bunch of times). It's not great, but it works.
Medium term solution is to fix the image files (no GIFs, etc).
Mike Pumphrey
OpenGeo - http://opengeo.org
tomorrow.
I have tried that but the pdf turned out pretty bad in some places. Theres
alot of overlapping, tables not generating probably and some images not
showing.
Mike Pumphrey
and
the
tomorrow.
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/Geoserver-2.0.2-release-tp28619049p28653275.html
