[Geoserver-devel] GeoServer 2.0-RC2 help
RC2 wise, here is an executive summary with the
short list of things I'd be glad to receive help on given
the day is over and tomorrow I'll be leaving for Sydney:
- pdf build failed. Don't know if it's the fault of my Latex
   or if there is a real issue. We have no PDF docs
- people giving the artifacts a kick before we announce publicly
- announcements, on ml and blog
Any takers?
Andrea Aime
OpenGeo - http://opengeo.org
So, I got the latex docs building again, and fixed a couple of dozen build warnings while I was at it. I'm not sure what the proper way is to handle this update; shall I just commit against the tag? Anyway, the fixes are there on trunk, and I've put copies of the documentation PDFs in
http://atlas.openplans.org/~dwinslow/geoserver_docs_temp/ as I'm not able to upload directly to SourceForge.
As for the actual issues:
* there was one weird Latex issue
* .gif is not understood by (at least my installation of) latex, so please don't use them. (Note that Sphinx lets you omit the file extension, so you can provide multiple versions of an image and it selects the "best" one for each format, so if you really need a .gif in the HTML version, you can still do that.)
* Latex also doesn't understand image file links with multiple '.'s in them, so don't use those either. I updated the images in SVN to use underscores.
* The PHP REST Examples are not there. I imagine this is just a missed commit.
* The Image Mosaic tutorial was linked as image_mosiac. :frowning:
David Winslow
OpenGeo - http://opengeo.org/
On 10/14/2009 05:27 PM, Andrea Aime wrote:
Any takers?
Hello Andrea,
I’m trying out the artifacts on Windows Vista.
I will report asap
Eng. Alessio Fabiani
Founder / CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
http://geo-solutions.blogspot.com
On Wed, Oct 14, 2009 at 11:27 PM, Andrea Aime <aaime@anonymised.com01…> wrote:
short list of things I’d be glad to receive help on given
the day is over and tomorrow I’ll be leaving for Sydney:
  • pdf build failed. Don’t know if it’s the fault of my Latex
  • people giving the artifacts a kick before we announce publicly
  • announcements, on ml and blog
Any takers?
Andrea Aime
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
Geoserver-devel mailing list
The artifacts work fine on Windows Vista, the only issue I found is that the ng one performs the installation correctly but later there is no way to start the GeoServer service, but this should be a well known issue I guess.
I hadn’t chance to try the .dmg artifact.
Alessio.
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Oct 15, 2009 at 10:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hello Andrea,
I will report asap
Via Carignoni 51
55041 Camaiore (LU)
On Wed, Oct 14, 2009 at 11:27 PM, Andrea Aime <aaime@anonymised.com> wrote:
Any takers?
Andrea Aime
I just tried out the OS-X, the bin and the war, and all worked fine. I uploaded David's pdf artifacts, hopefully they should show up soon.
I'll do the announcements shortly.
I hadn't chance to try the .dmg artifact.
       Alessio.
Via Carignoni 51
55041 Camaiore (LU)
On Thu, Oct 15, 2009 at 10:43 AM, Alessio Fabiani <alessio.fabiani@anonymised.com <mailto:alessio.fabiani@anonymised.com>> wrote:
    Hello Andrea,
    I'm trying out the artifacts on Windows Vista.
    I will report asap
    Via Carignoni 51
    55041 Camaiore (LU)
    <mailto:aaime@anonymised.com>> wrote:
        Any takers?
        Andrea Aime
        Jumpstart your
        and stay
        now!
        <mailto:Geoserver-devel@lists.sourceforge.net>
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9 - 12, 2009. Register now!
Chris Holmes
Hey Andrea;
You are probably on an airplane by now - thank you for all the hard
work getting this one out the door.
Jody
On Thu, Oct 15, 2009 at 8:27 AM, Andrea Aime <aaime@anonymised.com> wrote:
Any takers?
Andrea Aime
