I haven't put a lot of thought into the new 2.0 "Geo Application
Framework" so I don't really know where - exactly - its going. But, I
though I'd throw a few ideas out so people can put their 2 cents in
too...
There's been a bit of trend to not put components in Geotools, which I
hope is turning around. At least everyone is talking about re-merging.
Catalog is something that really needs to be stuck back in geotools as
almost everyone doing non-trivial projects needs one. Paolo already
mentioned some ideas on this, and I know that Jody, Chris and I have
also mentioned it.
In generic terms, I think the new architecture will look something like
this (Jody and Chris have already talked about this):
1. The "Core GeoServer" will be quite small, and basically serve as the
container for other services and handle such tasks like:
* taking requests and routing them to the correct plugin service
* manage the Dataset catalog
* manage configuration (often being passed off to the service
plugins)
* Anything else we think is a "common good" that will
make building and managing services easier
2. WFS/WMS/WCS will be example services that people could either
download-and-plugin or would come as separate downloads.
Each of the plugins would be responsible for handling the actual
requests, and any service-specific configuration. The plugins would
use the framework core to help implement the actual services. They
would also be responsible for all their configuration (including the
web-app to actually do the config).
This differs from the "GeoCollaborator" system which isn't really
supposed to be smart and build new services up from scratch - its
supposed to enhance existing services. Geoserver 2.0 is supposed to
make it a easier to develop and deploy new services.
I'm not sure exactly what this will look at - this is something we
really need to spend time and hammer out. There's lots of pros-and-cons
of putting different services (or service-helpers) in the core or
making the sub-components completely responsible for them. And example
would be security and user authentication; where (exactly) should it be
managed - there's lots of different places to put it.
(Feel free to reply with better suggestions and comments)
Personally, I think this is a pretty ambitious task thats going to take
quite a bit of time to actually pull-off. This is especially so if we
try to actually implement these things inside geotools instead of
having complete control inside geoserver. The unfortunate situation is
that, certainly from a web-configuration perspective, geoserver maybe
at variable stages of "unuseable" during the lengthy transition.
(As an aside, I believe jody and his team spent a lot of time on just
the STRUTs web app for config - see jody's message on this.)
I think you can see that the two biggest things to change will be (1)
the catalog stuff and (2) the config stuff.
I keep repeating myself, but for people doing things like the ingestion
engine need to just be warned that things will be changing in the
future so make sure that you make the program easy-to-change. I don't
think there's going to be any radical changes (we're still going to
have datastores and feature-type, etc...), but how its organized and
the actual content could change significantly. I expect you folks to
be involved in all these decisions so its not something thats going to
sneak up on you.
There's been a bunch of good suggestions floating around from everyone
in this conversation.
I did like paolo's idea of using Features to represent configuration
information (like the catalog and security) so you can leverage
existing geotools infrastructure like datastore (persistence) and
filter (searching).
Alessio, also, had a bunch of good idea in his email messages.
In a more practical manner, I don't really know what the timeframe that
these major changes will take place. I think it will really depend on
what you folks want to do.
I'm a bit risk-adverse on the issue since I want to ensure that
Geoserver is always getting better - easier to configure and more
stable. This might require a 1.3 branch and a radically different 2.0
branch, which can be a maintenance problem.
I talked to jody about moving some of the Udig work out of udig and into
geotools, and I'm not sure what his plan is for it. I dont think it was
something planned over the short time; and I've heard estimates from 2
weeks to 1 year.
Dave
This mail sent through IMP: https://webmail.limegroup.com/
