On Wed, Feb 22, 2017 at 5:35 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Checking over the blog post, it mentions YSLD moving to extension status.
Reviewing http://ares.boundlessgeo.com/geoserver/release/2.10.2/plugins/
I do not see the ysld module listed. We may need to mess with the release
scripts.
No need, it simply was not upgraded to supported status on 2.10.x, but only
on master.
See: https://github.com/geoserver/geoserver/tree/2.10.x/src/extension
and compare with:
https://github.com/geoserver/geoserver/tree/master/src/extension
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
