[Geoserver-devel] GeoServer 2.10.4 artifacts available for testing
The GeoServer 2.10.4 artifacts are available for testing from http://build-slave-01.geoserver.org/geoserver/release/2.10.4/
This is the first GeoServer release build using the new build.geoserver.org build server. If you have any trouble accessing the artifacts, please respond with details.
The Windows EXE and macOS DMG are currently unavailable. We are working on getting the relevant build processes tied into the new build server.
The PDF doc build is also unavailable - while we are working on getting this building, we are getting bogged down with miscellaneous LaTeX dependancies. There is a separate discussion on the list about whether anyone uses the PDF docs (we don’t seem to provide them for download anywhere).
Pursuant to this, does anyone think the PDF build is actually necessary / useful anymore?
Any help testing the artifacts would be appreciated.
Torben
Updates:
The PDF doc build is now available. Based on feedback from the user list, not many people know the PDF docs exist, but of those who do, most consider them valuable. We should perhaps consider making the PDF docs more available - currently they our only available on the build server - they don’t get uploaded to sourceforge.
The Windows EXE and macOS DMG are now available on http://ares.boundlessgeo.com/geoserver/release/2.10.4/
This is an interim solution while we get the Windows and Mac build boxes working with the new server - they will eventually be tied into the new build box properly.
I have done a brief smoke test of the macOS DMG, and everything seems to be in order.
Torben
On Tue, Jun 20, 2017 at 5:27 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
On Wed, Jun 21, 2017 at 11:22 PM, Torben Barsballe <
Updates:
don't get uploaded to sourceforge.
Agreed.
Mind, if you shearch pdf generation in the devel list archives there is a
thread were I explain what I did to make
it work on my machine, maybe that helps (mind, old thread, years ago)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
