Dear all,
the build of GeoServer 2.10.x is currently failing due to the following error
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geopkg: Compilation failure
[ERROR] /var/lib/jenkins/workspace/geoserver-2.10.x/src/community/geopkg/src/test/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormatTest.java:[64,25] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] [http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException](http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException)
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
