[Geoserver-devel] GeoServer 2.10-M0 artifacts available for testing
The GeoServer 2.10-M0 artifacts are available for testing:
http://ares.boundlessgeo.com/geoserver/release/2.10-M0/
(OS X DMG is still building [or perhaps has failed] and should be ready shortly - I can test this one)
Torben
Jody - looks like the mac build failed as per usual - would you be able to build and upload manually?
Torben
On Fri, Aug 12, 2016 at 6:44 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
This build failure is the same was as previous:
bootstrap:
[mkdir] Created dir: /Users/jody/Downloads/geoserver-2.10-M0-mac/lib
[get] Getting: https://boundless.artifactoryonline.com/boundless/main/com/oracle/appbundler/1.0ea/appbundler-1.0ea.jar
[get] To: /Users/jody/Downloads/geoserver-2.10-M0-mac/lib/appbundler-1.0ea.jar
[get] Error opening connection java.io.FileNotFoundException: https://boundless.artifactoryonline.com/boundless/main/com/oracle/appbundler/1.0ea/appbundler-1.0ea.jar
We need to fix our script, monkey patching locally for now and making the DMG
On 12 August 2016 at 18:49, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Jody Garnett
Torben
WAR looks good
Torben
On Fri, Aug 12, 2016 at 6:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
bootstrap:
Jody Garnett
Torben
Torben
I tried the Windows installer with the Install as a service option. Looks good.
One bug in the installer itself: If I select JRE version 1.6 or 1.7 the installer says that path contains a valid JRE which is not true because we need 1.8.
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe
Lähetetty: ‎13.‎8.‎2016 4:47
Vastaanottaja: geoserver-devel
Aihe: [Geoserver-devel] GeoServer 2.10-M0 artifacts available for testing
Torben
Jukka,
are you able to change the port with the Windows installer? We have a report that this setting is not honoured for 2.9.1:
https://osgeo-org.atlassian.net/browse/GEOS-7677
The setting works for 2.8.4 and 2.8.5. See the Jira issue for discussion and a workaround.
Kind regards,
Ben.
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe<mailto:tbarsballe@anonymised.com>
Vastaanottaja: geoserver-devel<mailto:geoserver-devel@lists.sourceforge.net>
Torben
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
No, I can't change the port, installer starts the service always at 8080.
My workaround is to edit the "start.ini" file as I write in my comment to GEOS-7677.
-Jukka Rahkonen-
________________________________________
Ben Caradoc-Davies wrote:
Jukka,
and a workaround.
Kind regards,
Ben.
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe<mailto:tbarsballe@…3839…>
Torben
Ben Caradoc-Davies <ben@...4191...>
Director
New Zealand
