[Geoserver-devel] GeoServer 2.11.0 artifacts not published to mvn
Turns out this was unrelated to the other issue with unexpected artifacts showing 2.11-SNAPSHOT
Short version: The 2.11.0 build failed due to a connection error with one of the downstream servers, meaning the proper version did not get commited/tagged, and leading to the wrong version being published to maven. This is now fixed.
Longer version:
The 2.11.0 geoserver-release build failed, but still produced valid artifacts (examining these artifacts shows the correct version).
These artifacts were not pushed to maven; instead a 2.11-SNAPSHOT was.
I have manually pushed the correct artifacts to maven, and updated the tag on geoserver.
The geogig community artifact did not get deployed, because it depends on some SNAPSHOT of the geogig project. There is not much we can do about this, since the geogig project does not use proper versioning.
I will be commiting a fix to the build_release.sh script so that even if a similar issue with the downstream servers occur in the future, the correct version updates will still get tagged and commited.
Torben
On Fri, Apr 28, 2017 at 9:56 AM, Torben Barsballe <tbarsballe@anonymised.com.3839…> wrote:
A similar issue appears to have affected the 2.11.0 release build as well: http://ares.boundlessgeo.com/jenkins/view/release/job/geoserver-release-publish/80/console
Looking at the build logs, it seems 2.11-SNAPSHOT got pushed to repo.boundlessgeo.com instead of 2.11.0, meaning there are no 2.11.0 artifacts available for maven.
Looking at the 2.11.0 tag, it looks like the section of the build that was supposed to update the version never ran, or failed in some way.
Torben
On Mon, Apr 24, 2017 at 4:22 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Thanks for the report, Jukka. The Windows installer and non-English user
docs were also affected. I have pushed a fix on master.
Kind regards,
Ben.
On 24/04/17 21:38, Rahkonen Jukka (MML) wrote:
This zip http://ares.boundlessgeo.com/geoserver/master/geoserver-master-latest-bin.zip from here http://geoserver.org/release/master/ contains directory named geoserver-2.11-SNAPSHOT but actually it delivers correctly 2.12-SNAPSHOP.
-Jukka Rahkonen-
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Director
Transient Software Limited <http://transient.nz/>
New Zealand
