[Geoserver-devel] GeoServer 2.11.0 release artifacts ready for testing
the release job just finished and the release artifacts are ready for testing:
http://ares.boundlessgeo.com/geoserver/release/2.11.0/
If I got Jody correctly, the OSX installer should show up, but the windows one won’t and
will have to be generated manually instead? Or something like that?
indeed the build failed at the end, after the uploads, with this:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
The windows build box is currently running (the installer job is in progress). However, due to ongoing issues, the installer build will be quite slow (between 5 and 9 hours).
Oddly enough, the above failure seems to be in communicating with the OS X build box, rather than the Windows build box.I have manually run the OS X build job, so we should be seeing a DMG soon. I will also look into why there was a connection failure.
Torben
On Wed, Mar 22, 2017 at 12:23 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
copying artifacts to /var/www/geoserver/release/2.11.0
starting installer jobs
executing installer job [http://162.209.53.106:8080/job/geoserver-installer/buildWithParameters?TAG=2.11.0&token=buildme](http://162.209.53.106:8080/job/geoserver-installer/buildWithParameters?TAG=2.11.0&token=buildme) with credentials build:c7df8777ad146449f39272c596e963e4
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0
executing installer job [https://desktop-ci.boundlessgeo.com:8443/job/geoserver-installer/buildWithParameters?TAG=2.11.0&token=buildme](https://desktop-ci.boundlessgeo.com:8443/job/geoserver-installer/buildWithParameters?TAG=2.11.0&token=buildme) with credentials build:7babda1c4cf05ee099baa3d4c6579dab
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (35) Unknown SSL protocol error in connection to [desktop-ci.boundlessgeo.com:8443](http://desktop-ci.boundlessgeo.com:8443)
Build step 'Execute shell' marked build as failure
Finished: FAILURE
Anyways, time for me to go cook some dinner, can anybody give the artifacts a kick?
If all goes well we’ll complete the release tomorrow morning
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
We needed some warning before that release job, I get ready and rerun the build.
Finished: FAILURE
Ing. Andrea Aime
@geowolf
Technical Lead
I have tried out the OS X DMG build artifact, everything seems fine.
I’m not quite sure what you mean here, Jody.
Torben
By chat he told me “windows build box is screwed up so send an email when ready.” But I did not understand that I was supposed to mail before running the job, I thought I had to mail after the job to get the installer done instead. Sorry!
No problem Andrea, it seems like the Windows build box was online at the time, so everything is fine.
Torben
On Wed, Mar 22, 2017 at 1:51 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody has started a blog post for the release. I’ve given it a read-over and fixed up some typos.
There is still some room for more content (e.g. an example of the REST API password endpoint).
The “And more” section at the bottom could also be split up into separate sections.
Torben
On Wed, Mar 22, 2017 at 1:59 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
On Thu, Mar 23, 2017 at 1:23 AM, Torben Barsballe <
Jody has started
<http://blog.geoserver.org/wp-admin/post.php?post=2825&action=edit&gt; a
blog post for the release. I've given it a read-over and fixed up some
typos.
password endpoint).
Thanks for getting it started, I've completed the REST API section, added
"thanks" where missing.
Ing. Andrea Aime
@geowolf
Technical Lead
Looks like the exe is being uploaded now (still in progress, about 25% uploaded). Job has been executing for 20 hours, slowest time I have seen yet :frowning:
Torben
On Thu, Mar 23, 2017 at 1:58 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Mar 23, 2017 at 1:23 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Thanks for getting it started, I’ve completed the REST API section, added “thanks” where missing.
Ing. Andrea Aime
@geowolf
Technical Lead
Verified that https://osgeo-org.atlassian.net/browse/GEOS-7919 is not fixed in 2.11.0 and reopened the issue, this is a nice-to-have and does not block the release.
On 22 March 2017 at 12:23, Andrea Aime <andrea.aime@anonymised.com> wrote:
Finished: FAILURE
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
I see the upload is not completed yet… wow :slight_smile:
I guess I’ll hit the release-publish job tomorrow then?
How are we doing blog post wise, good to go?
On Thu, Mar 23, 2017 at 5:14 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
publish now, we can update the blog post when exe is up.
On 23 March 2017 at 11:42, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ok, done. There is some traffic on the build server, it’s going to be a while I’m afraid.
On Thu, Mar 23, 2017 at 7:43 PM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Just checked, thanks for the updates. Fixed a heading, and changed the
link at the top to point to http://geoserver.org/release/2.11.0/ Think if
we update the website we are ready to publish.
Done for the day, family needs taking care of. I can follow up tomorrow morning
On Thu, Mar 23, 2017 at 7:51 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Just checked, thanks for the updates. Fixed a heading, and changed the link at the top to point to http://geoserver.org/release/2.11.0/ Think if we update the website we are ready to publish.
Ing. Andrea Aime
@geowolf
Technical Lead
