On Mon, Mar 27, 2017 at 11:13 AM, <Herve.Minko@anonymised.com> wrote:
Hello everybody,
I just downloaded the released geoserver 2.11.0 project sources and see
that the project pom.xml still contains 2.11-SNAPSHOT as version number
instead of 2.11.0.
Does anybody knows why it is the case?
Confirmed, it's like that in the tag as well:
https://github.com/geoserver/geoserver/tree/2.11.0
However the 2.10.2 release does not have the same problem, and the
automated release scripts are supposedly the same.
Humm... that might be cause the release build failed at one point trying to
start the generation of the windows/osx installers.
We probably want to modify those scripts to fist commit and then start the
remote jenkins jobs doing the installers:
https://github.com/geoserver/geoserver/blob/2.11.0/build/build_release.sh#L361
Can I simply change the parent project version from 2.11-SNAPSHOT to
2.11.0 to get desired maven dependencies?
Probably so, yes
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
