[Geoserver-devel] GeoServer 2.11.2 test artifacts ready for quick tests (and help needed for Win/OSX installers)
has anyone some time to give the 2.11.2 release artifacts a quick spin?
http://ares.boundlessgeo.com/geoserver/release/2.11.2/
As far as I know the windows and OSX builds are not going to show up, not sure
what to do about them? They both need to be signed right?
I can boot in Windows if that helps, but how do I go about building the artifact these days?
I haven’t done so in years.
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
For OS X, the machine responsible for building artifacts is still available, but is retiring soon. I have restarted the build there, so we should get OS X artifacts.
In general, it is not possible to sign the OS X or Windows artifacts on your own machine, because only a very small group of people have permissions / access to the OSGeo signing certificate (this is part of the reason why it has been taking so long to get the windows build on build.geoserver.org working) - if you are one of the people who does have access, then I guess this is not an issue.
Nick just got the cert for signing the Windows builds on build.geoserver.org last week, so you might be able to use that (perhaps with a bit of extra config on the build to get it to pull from ares).
If you are running the windows build on your own computer, you’ll need NSIS and a few plugins, and should just be able to run the build/win_installer.sh script.
Torben
On Mon, Jul 31, 2017 at 9:09 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Update:
The OS X build ran fine, the dmg is now available at http://ares.boundlessgeo.com/geoserver/release/2.11.2/
I’ve done a quick test of the dmg, and it starts up fine, and everything looks correct.
I’ve also kicked of a 2.11.2 windows build on build.geoserver.org (with a modified configuration that pulls the correct artifacts on ares).
Running into a few issues there getting the new cert working, but otherwise seems to be going well. Should have something shortly.
Torben
On Mon, Jul 31, 2017 at 9:43 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hi Andrea,
Torben
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.comrge.net
The windows build on build.geoserver.org built and signed the exe, although it wasn’t able to copy the resulting artifact over to ares due to permissions issues. Once we fully move to build.geoserver.org, this will not be an issue.
I have manually copied the exe over to ares: http://ares.boundlessgeo.com/geoserver/release/2.11.2/geoserver-2.11.2.exe
It should be correctly signed, but it would be nice if someone who is natively on windows could test.
Torben
On Mon, Jul 31, 2017 at 9:58 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Update:
Torben
Hi Andrea,
Torben
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I gave a spin at the bin file, seems to be working fine.
Since tomorrow I’m in vacation (and for the rest of the week), I’ll go ahead and hit the publish button now :slight_smile:
On Mon, Jul 31, 2017 at 7:33 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Update:
Torben
Hi Andrea,
Torben
On Mon, Jul 31, 2017 at 9:09 AM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
